Author Topic: 1198 looses screen when going over 10mph .any help iut there???  (Read 26270 times)
Offline kooterpatrol
  • Unit(s): 1198
1198 loose screen when going fast . any help out there
Re: 1198 looses screen when going over 10mph .any help iut there???
« Reply #1 on: April 22, 2014, 02:35:06 PM »
Welcome to the Humminbird Side Imaging Forums kooterpatrol.
Is this a new unit/installation?
What transducer(s) are you suing with the 1198 unit?
Where is/are the transducer(s) installed?
What type of boat do you have?
  • Unit(s): 1198
« Reply #2 on: April 22, 2014, 02:48:21 PM »
1 year old Its got side and down image
27ft searay
bottom right below kicker motor
i think its the hd transducer its pretty big
« Reply #3 on: April 22, 2014, 03:04:57 PM »
So did this same set-up work at speeds faster than 10mph for the first year?
  • Unit(s): 1198
« Reply #4 on: April 22, 2014, 03:09:04 PM »
no allways went goofy when start going over 10 mph
sounds like it may b postion of transducer? i dont no been waiting on buying another to i figure it out
« Reply #5 on: April 22, 2014, 03:13:44 PM »
It probably is the installation of the HDSi transducer than kp.
I believe that a Searay is a fiberglass boat, right?  You could install an inside-the-hull DualBeam (XP-9-20) transducer and an AS-Si-DB-Y cable and get better high speed water depth readings or you could try adjusting or moving the HDSi transducer you have now.  If you want to try and adjust it or move it, try posting some pictures of the transom area of your boat’s hull.  We need to see it from left, right and behind and at a low angle (about the same height as the transducer).
Does your Si sonar look good where the transducer is now?
  • Unit(s): 1198
« Reply #6 on: April 22, 2014, 04:13:25 PM »
ya works good when trolling
ill take pics tommorrow
thanks
  • Unit(s): 1198
« Reply #7 on: April 25, 2014, 09:52:09 AM »
heres a couple pics of transducer just bought another 1198 yesterday should  imount it on other side(port)
« Reply #8 on: April 25, 2014, 12:28:04 PM »
kp,
The pictured HDSi transducer will have to be lowered down quite a bit to enable high-speed water depth readings and the left Si sonar is being blocked.  Refer back to the installation instructions for how low it should be or go with an inside-the-hull DualBeam transducer (maybe the XAP-9-20 Angled-Puck inside-the-hull DualBeam, in your case).  From the looks of it you may also have to mount another HDSi transducer on the left side of the motor to keep it from blocking the left Si sonar (an AS-Si-LR-Y cable would be needed for this).
Where is the 1198 you have now mounted and where are you planning on installing the second 1198 unit?
How is each unit going to be used; both displaying sonar or one sonar and one GPS,…?
  • Unit(s): 1198
« Reply #9 on: April 25, 2014, 12:58:22 PM »
the one on the boat now is by the steering wheel used for everything
new one is going on rear mostly for seeing structure n fish
« Reply #10 on: April 25, 2014, 01:04:41 PM »
Maybe you should mount the second 1198’s transducer on the left side of the motor, install a DualBeam transducer inside-the-hull and connect all the transducer together with an AS-Si-LR-Y cable and an AS-Si-DB-Y cable. Then network the two 1198 units together.  No interference between the two units, no blockage of the Si sonar and it should read much better above 10 mph.
  • Unit(s): 1198
« Reply #11 on: April 25, 2014, 01:18:10 PM »
k ill wii need a ethernet cable to right??
does the inside of hull trans just shoot thru bottom of boat
heres anther pic
  • Unit(s): 1198
« Reply #12 on: April 25, 2014, 01:37:01 PM »
i could only find thru the hull trans cant i just add a speed n temp trans n tie that n with the 2 hd tran
« Reply #13 on: April 25, 2014, 02:30:45 PM »
Yes, to Ethernet the two 1198c Si units together you will need an Ethernet Connection Cable (AS-EC-XXE where the “XX” is the cable length.  Comes in 2, 10, 15, 20 and 30-foot lengths).
An inside-the-hull (aka: shoot-thru) transducer will transmit/receive the sonar out of the bottom of the boat.
A speed n temp  transducer will only give you water speed and temperature, not sonar.  Look for the XP-9-20 or since your boat has such a high deadrise angle the XAP-9-20 transducer.
  • Unit(s): 1198
« Reply #14 on: April 25, 2014, 02:37:21 PM »
k thanks for all the help
  • Unit(s): 1198
« Reply #15 on: April 25, 2014, 02:52:31 PM »
whats the difference between the 2 trans they look the same
« Reply #16 on: April 25, 2014, 03:35:10 PM »
The XP-9-20 and XAP-9-20 transducers?  The XAP has a 14 degree angled bottom so it that it will allow the transducer to point more directly downwards when mounted inside-the-hull of a boat.
If you don’t think that this will be enough of an angle I’ve got an alternative you could use.
  • Unit(s): 1198
« Reply #17 on: April 25, 2014, 04:58:57 PM »
k thanks again gonna try the xap-9-20
  • Unit(s): 1198
« Reply #18 on: April 25, 2014, 05:01:05 PM »
will i need another lakemaster cord or will the ethernet cable link that too
  • Unit(s): 1198
« Reply #19 on: April 27, 2014, 09:38:26 PM »
do i hook up thru hull beam to front unit and what do i hook the as-lr-y cable to the front unit
« Reply #20 on: April 28, 2014, 12:48:52 PM »
You will need another LakeMaster mapping card if you want those maps to appear on both units.
« Reply #21 on: April 28, 2014, 12:51:38 PM »
I would connect all transducers up to your console mounted unit and, through the Ethernet connection, share the sonar to the second 1198c Si unit.
Both HDSi transducers connected to the AS-Si-LR-Y cable.
This gets connected on the “Side Imaging” side of the As-Si-DB-Y cable.
The XAP transducer gets connected to the “Dual Beam” side of the AS-Si-DB-Y cable.
All this gets connected to the console mounted 1198 unit.
« Reply #22 on: April 30, 2014, 12:20:07 PM »
The Ethernet connection will allow you to share the GPS Receiver as well.  I would use just the one GPS Receiver and keep the other as a spare for back-up just in case.
  • Unit(s): 1198
« Reply #23 on: May 02, 2014, 09:29:10 PM »
i got the wrong transducer. whats the part # for thr xap 20 i need for the1198???cant find any that are compatable now and when i hooked both side image trans together it nows says like 1000 ft deep
« Reply #24 on: May 05, 2014, 12:26:29 PM »
XAP 9 20 | Shoot Thru The Hull | 710165-1
http://www.humminbird.com/Products/XAP-9-20/
Without a DualBeam transducer connected the unit has no way to determine water depth.
  • Unit(s): 1198
« Reply #25 on: May 11, 2014, 09:27:58 AM »
thanks again got everything all hooked up gonna test it out soon
Last post September 10, 2010, 04:04:56 PM
Last post January 19, 2011, 06:59:18 PM
Last post September 11, 2012, 01:46:41 PM
Last post April 15, 2013, 12:51:21 PM
Last post July 22, 2013, 03:07:31 PM
Last post May 22, 2015, 01:17:41 PM
Last post February 09, 2017, 07:18:27 PM
Last post January 04, 2021, 09:50:10 PM
