Author Topic: DI comes on goes away  (Read 3976 times)
Offline stpafford
  • Unit(s): 898sidi
« on: April 15, 2014, 09:27:32 PM »
When I go to the DI it opens up and looks great and then on the right side of the screen it looks like graph paper coming across the screen. I can switch to another screen and come back its ok and then it starts the thing again. What can I do the fix this problem?
Re: DI comes on goes away
« Reply #1 on: April 15, 2014, 10:40:00 PM »
While viewing a DI view...
*Press Menu once to open the DI Xpress menu...
*Cursor down to DI Enhance...
*Cursor right to open the DI Enhance sub menu...
*If "Sharpness" in the sub menu is set to anything other than "Off" ...turn Sharpness Off...
If the problem goes away...this is a known issue with all versions of software above about 6.1xx...
If your problem still persists...it is a different issue (where you would need to post pix for diagnosis)...
« Last Edit: April 15, 2014, 10:42:38 PM by rnvinc »
Offline stpafford
  • Unit(s): 898sidi
« Reply #2 on: April 16, 2014, 09:51:32 PM »
Thanks!  I'll try that.
Offline stpafford
  • Unit(s): 898sidi
« Reply #3 on: April 20, 2014, 09:48:46 PM »
I want thank you. I tried what you said to do and it fixed my problem.  Thanks again !
