Author Topic: Connecting a Onix 10 SI to I pilot link  (Read 12162 times)
Offline nwifishnut
  • Unit(s): Onix 10 si, Onix 8ci
  • Software: 2.3
  • Accessories: I-Pilot Link,ASGPS HS,Lakemaster WI v5.0
« on: April 14, 2014, 02:24:02 PM »
Had planned to buy a 1199, but decided to move up to the new technology. So, with a much depleted checking account, I have a new Onix 10, a Lakemaster V5 chip & a 80 lb Terrova with I pilot link & US2 in transit to me.
2 questions:  1. What cable do I need to connect the Onix to the I pilot link?  2. I have an older Humminbird 917 c (917 has no Ethernet capability) that I plan to connect to the US2 on the Terrova.  Is there a way for the US2 to be used with 917 c & the Onix?  If so how and what cables etc do I need?
Also, you really need an Onix specific forum!
  • Moderator
Re: Connecting a Onix 10 SI to I pilot link
« Reply #1 on: April 14, 2014, 04:39:42 PM »
The i-Pilot Link should come with the needed connection cable to your ONIX 10ci Si unit.
The only way for both the 917c and the ONIX 10ci Si unit can both use (not at the same time) the US2 transducer would be with a switch.  Humminbird does not make a switch for use with both of these types of transducer connectors so it would have to be something that you make yourself or you would have to buy a transducer switch, an adapter cable and the correct ONIX adapter cable for the US2.
“Also, you really need an Onix specific forum!”
Oh, Robert…  :D
Offline nwifishnut
  • Software: 2.3
« Reply #2 on: April 14, 2014, 04:55:04 PM »
Greg,
Thanks, I think I will pass on the switch for the 917c. It's a nice to have vs need to have.
Robert.....Hello Robert, wherever you are.  We need an Onix Forum!
Offline nwifishnut
  • Software: 2.3
« Reply #3 on: May 21, 2014, 09:56:46 AM »
Greg,
The Onix 10 and Terrova have arrived and I am in the process of hooking them up.  I have decided not to use the 917c as previously planned, but instead will hook the Terrova US2 sonar to the Onix 10.  Is there a cable (or cables) available that will allow me to hookup the US2 in conjunction with the Onix 10  SI?   I looked on the Humminbird website but could not find it.  I have trouble finding things in the accessories section of the site.
  • Moderator
« Reply #4 on: May 21, 2014, 12:00:32 PM »
I don’t think it is listed on the Humminbird web site or at least not yet.  Try the Minn Kota MKR-US2-13 cable.  You should be able to order it through the Humminbird Customer Resource folks as well as the Minn Kota folks.
Offline nwifishnut
  • Software: 2.3
« Reply #5 on: May 21, 2014, 03:25:38 PM »
Greg,
Last post July 18, 2012, 08:09:44 AM
Last post February 10, 2013, 03:26:46 AM
by didier74
Last post February 26, 2013, 10:09:37 AM
Last post April 18, 2013, 03:56:39 PM
by Rotus623
Last post April 16, 2013, 12:42:46 PM
by scgmc
Last post April 23, 2013, 09:56:43 AM
by freezerfiller
Last post July 04, 2014, 12:11:47 AM
by CarolC
Last post April 27, 2015, 09:15:44 AM
