Author Topic: Re: First Shots  (Read 5787 times)
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
Re: First Shots
« on: March 20, 2014, 07:49:30 PM »
Chuck when your running passes looking at the area in SI do you tilt your motor up?
Tell them I've gone fishing!
Offline chuck41
  • I'd rather be fishin'
    • Lake Ouachita Arkansas
  • Unit(s): 798ci si di Combo
Re: First Shots
« Reply #1 on: March 21, 2014, 03:10:22 AM »
No.  My motor sits slightly in front of the location of the transducer so tilting it up does not help.  It still completely blocks the line of the transducer.
At safe operating angles for cooling for the motor it actually makes things worse.  I only tilt it up if I am running shallow areas or areas with heavy stumps to look out for. No advantage now.  When the third pontoon is installed the motor will go almost a foot further aft and I will modify the bracket where the transducer is mounted to move it about 4" forward.  I am hopeful that then tilting it up should help.
A bad day on the lake is still better than a good day at work!
Last post July 04, 2010, 03:45:14 PM
Last post February 17, 2011, 12:52:37 AM
by Enufzed
Last post September 25, 2011, 01:59:51 AM
by 49thdiver
Last post October 06, 2013, 06:46:24 PM
by slabbacks
Last post March 20, 2014, 12:53:02 PM
by FlyFisher SLC
Last post August 24, 2014, 10:25:23 PM
Last post March 28, 2015, 04:54:37 AM
by vik33
Last post May 27, 2016, 11:47:40 PM
