Author Topic: First try with Di  (Read 14960 times)
Offline soretoe
First try with Di
« on: February 07, 2010, 08:10:02 PM »
Was out fishing with a friend last Wednesday and made a feeble attempt at setting my unit up. The pics below are basically at factory settings. This was a therapy trip for my buddy so we mostly fished.
This first pic is of what is left of a tree that was sunk in a 55 gallon drum.
The next two are shots of bait (shad). They were approx 1 inch to 1 and a half inches long.
I can also be found at;
Re: First try with Di
« Reply #1 on: February 07, 2010, 08:18:49 PM »
Whats up with the SI in the first image?  The right side is bright and the left is dark?  I like the rock or barrel? in the Down Imaging!
« Last Edit: February 07, 2010, 08:20:30 PM by RGecy »
Offline soretoe
« Reply #2 on: February 08, 2010, 09:26:16 PM »
I have two different transducers for one thing. I have been having weird stuff happen even before the upgrade. Sometimes the whole left side just disapears, almost like when ya have a transducer on the trolling motor and are turning.  I'm going to spend a day out on the lake soon and get more pics of the left side. I hope to disconnect the "Y" cable and let it all run on the HD ducer to see if if happens there too.
Here is a shot of it being almost gone.
« Reply #3 on: February 08, 2010, 11:44:30 PM »
Definitely an issue!  Hopefully its just the cable or something inexpensive!  My guess though is its probably the transducer!
Good Luck and let us know how it works out.
Offline soretoe
« Reply #4 on: February 09, 2010, 05:39:59 AM »
Will do.
Offline Chiboo
  • SpearFishing
  • Unit(s): Solix 10 MSI+ G3
  • Software: 4.130
« Reply #5 on: February 09, 2010, 09:07:10 AM »
Such impression that a boat with  transducer or only  transducer has an inclination to the right, therefore the left-hand side has a weak returnable signal
Offline wizzo86
  • diving in phillapenes
« Reply #6 on: February 09, 2010, 10:32:35 AM »
 I had that problem last year. Thought something on the boat was blocking the ducer view; but, I did not change anything on the boat. I took the plastic peace that all the wires go into apart. The one that has one screw to the head unit. I take my head unit off the boat each trip. That's what it was. A loose plug from the ducer cable to the head unit.
Offline soretoe
« Reply #7 on: February 09, 2010, 06:59:09 PM »
I'll have to check my connections. I just havent had any time on the water. Hope to rectify that soon.
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
« Reply #8 on: March 05, 2010, 09:20:42 AM »
If in the worse case it is the transducer, you might get lucky and it is only the left side element.  Swapping transducers on your transom could get you back  in working order, without the expense of a new SI ducer..
JohnS
http://joefishin.com/
Offline Singleshot
  • Unit(s): 798c Si
  • Software: 4.780
  • Accessories: n/a
« Reply #9 on: March 05, 2010, 01:05:33 PM »
If it's not a loose or questionable connection, do you think that tweeking the xducer down towards the weak side would make a difference???  I'm patiently waiting for the water to soften here to get mine out.
JK
To ignore the facts does not change the facts.
