Author Topic: 998c SI  (Read 6789 times)
Offline Kenosha
  • Unit(s): HB 898
998c SI
« on: March 08, 2014, 08:42:41 PM »
The zero line at the top is at 2 feet. I tried Depth Offset that moves it to zero but subtracts it from the depth reading making
the depth reading in error. Is there a zero adjustment some place,that will move the entire display to zero it  and keep the correct dept reading. It always has had this problem. The unit is 4 years old.
HB Version 6.180
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
Re: 998c SI
« Reply #1 on: March 09, 2014, 09:12:58 AM »
Press the menu key once to go to the Sonar Express Menu and check what the Upper Range is set to. If it's other than zero, change it to zero.
By using this feature you can eliminate surface clutter, etc., or look from a specific depth to the bottom, by changing the setting to 10 feet or whatever.
Whatever this is set to is the depth point where the graph begins to display.
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
Last post May 12, 2010, 12:52:44 PM
Last post June 21, 2010, 10:44:34 PM
Last post December 15, 2012, 12:10:23 PM
by Jim Jack
Last post January 23, 2014, 10:20:52 AM
by RuffWood
Last post February 28, 2014, 03:19:45 PM
by kabrams001
Last post August 29, 2015, 11:00:48 AM
by hatchetman
Last post March 21, 2016, 08:50:07 PM
Last post June 07, 2019, 08:26:36 PM
