Author Topic: 899 c si hd  (Read 4157 times)
Offline Birdhunterden
  • Unit(s): 898c si
  • Software: ?
899 c si hd
« on: February 17, 2014, 11:09:34 AM »
What transducer  will I need for the tm
Re: 899 c si hd
« Reply #1 on: February 18, 2014, 09:26:48 AM »
That depends…
If you want to only use the 200/83kHz 2D sonar along with the 455kHz Si/Di sonar off the trolling motor then you need the XTM-9-Si-180-T Compact Side imaging (CSi) transducer.
If you want to use the 200/83kHz 2D sonar along with the 455kHz and 800kHz Si/Di sonar off the trolling motor then you need the XTM-9-HDSi-180-T High Definition Side Imaging  (HDSi) transducer.  The 455kHz si/Di sonar will be sharper than with the CSi transducer.
  • Unit(s): 898c si
  • Software: ?
Re: 899 c si hd
« Reply #2 on: February 18, 2014, 09:40:41 AM »
Thank you
Re: 899 c si hd
« Reply #3 on: February 18, 2014, 10:23:24 AM »
If you have not already opened the transducer that comes with your 899ci HD Si unit: call the Humminbird Customer Resource folks and see about exchanging your new and unused transom mounted XNT-9-Si-180-T transducer for one of those I listed above.
