Author Topic: Trolling motor transducer  (Read 10863 times)
Offline Meena
  • Unit(s): 798
« on: February 11, 2014, 05:02:12 PM »
I think I have seen this discussed before but I have a 798ci  with the SI compact transducer and was wanting to exchange it for a trolling motor one. Are the crystals the same in both and is the trolling motor one just as good?   Looks like it is a available for the exchange program HB has.
Re: Trolling motor transducer
« Reply #1 on: February 11, 2014, 05:56:12 PM »
 I'm pretty sure SI crystals are the same for the stock XNT 9 SI 180 T (Compact SI)..and the TM puck style XTM 9 SI 180 T...
Some have opted to trade for the XHS 9 HDSI 180 T ...which has longer SI crystals...which should give sharper SI images..
The XHS 9 HDSI 180 T can operate at 455kHz and 800kHz ...but your 798 can only transmit the 455kHz frequency...but it still may be worthwhile to get the longer crystals...
The HDSI also comes in a TM version....which is basically the transom HDSI with hardware to adapt to the TM...
http://store.humminbird.com/products/314024/XTM_9_HDSI_180_T
Transducer Shield and Saver makes an aftermarket sturdy bracket for the XHS 9 HDSI 180 T to mount to the TM...
http://www.transducershieldandsaver.com/home/transducers?page=shop.product_details&flypage=flypage.tpl&product_id=11&category_id=5
« Last Edit: February 11, 2014, 06:02:04 PM by rnvinc »
« Reply #2 on: February 12, 2014, 01:10:40 PM »
Rickie is correct : the transom mounted XNT-9-Si-180-T transducer and the Trolling Motor mounted XTM-9-Si-180-T transducer both use the same elements for the Si/Di sonar (and the 2D sonar).
Last post June 05, 2009, 11:39:51 AM
Last post April 11, 2010, 02:35:10 AM
by tennwalkinghorse
Last post January 02, 2012, 07:40:33 AM
by tommy29461
Last post May 19, 2011, 11:55:14 AM
by FuzzyGrub
Last post January 14, 2013, 01:12:34 PM
Last post March 07, 2013, 04:43:32 PM
by Turk
Last post February 27, 2014, 11:47:57 AM
Last post February 27, 2014, 09:48:03 PM
