Author Topic: imageJforXtf  (Read 8168 times)
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
imageJforXtf
« on: February 07, 2014, 06:48:27 AM »
Has anybody tryed this opensource projetct "imageJforXtf"?
http://sourceforge.net/projects/imagejforxtf/
Offline Nitro78
  • French frog
  • French frog!
  • Unit(s): Solix mega
  • Accessories: TM265 LH + 2 side imagin transdeucer an
Re: imageJforXtf
« Reply #1 on: February 07, 2014, 08:45:21 AM »
Will test this WE thanks to share ypur information! ;)
Offline salado
  • 798ci HD si
  • 798CiHD
    • youtube
  • Unit(s): 798ci HD si
Re: imageJforXtf
« Reply #2 on: February 07, 2014, 10:03:20 PM »
any tutorials how to layer more than one image down and blend them together. also can you get rid of the water column to get a better view of the bottom layout in Google earth?
« Last Edit: February 07, 2014, 10:11:33 PM by salado »
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
Re: imageJforXtf
« Reply #3 on: February 08, 2014, 10:13:18 AM »
That's pretty neat!! If you recorded in contour mode, maybe the water column would not show in picture?? Also, you could print screen, save, do the same with next slice, then use a photo editor (Gimp is free) to combine the two.  Quite a bit of work, but may be well worth it!!
