Author Topic: Navionics Maps and Sonar saved Data  (Read 9962 times)
Offline fgcity
« on: January 14, 2014, 06:07:12 PM »
Hi everyone.
I have the 798c SI sonar and recently got my self the Navionics Gold maps SD card.
However, i like to save the Sonar data to the Memory card and then open it up on my PC and view it later on with ReefMaster or other software.
After doing some reading, it turns out i cannot save the sonar data to the Navionics SD card since later on if i try to open the files on the PC, the maps will be destroyed due to the card format ?
Is there any way to keep the maps and transfer the sonar data to the PC?
Re: Navionics Maps and Sonar saved Data
« Reply #1 on: January 15, 2014, 04:30:40 PM »
If this is a 798 unit, it will have two SD card slots.  Install a blank SD card in the other slot and save away.
Online rnvinc
« Reply #2 on: January 15, 2014, 07:09:01 PM »
If your mapping card has a slide lock on it ...it would be a good idea to keep this in the locked position so that there is no way anything can be written to the mapping card accidentally ...and ruin the mapping card..
HB recommends the Sandisk brand SD Card for saving snapshots and recordings...and for exporting GPS data to...
Max card size is 32Gb and "faster write speeds" are beneficial (especially in saving screenshots and recordings)...
I use the Sandisk Extreme III SDHC 45mbps write speed...
« Last Edit: January 15, 2014, 07:12:37 PM by rnvinc »
Last post March 30, 2010, 07:51:51 AM
by Louis
Last post April 05, 2010, 12:27:00 AM
by muskyhunter
Last post April 18, 2010, 10:39:09 AM
by stillbear
Last post June 16, 2011, 05:11:49 PM
Last post January 02, 2012, 03:48:01 PM
by tommy29461
Last post July 12, 2012, 01:48:24 PM
by Johnf
Last post March 25, 2014, 12:56:24 PM
by jesse1378
Last post March 11, 2022, 11:39:22 AM
by Swann
