Author Topic: NEW 998C SI HD SET-UP  (Read 9323 times)
Offline lineman
  • Unit(s): 998c si hd
« on: January 10, 2014, 05:56:34 PM »
Just looking for some pointers on installation on a new 998c SI HD, just purchased my first HB unit moving over from the Lowrance world. If anyone has any suggestions to help me out it would be greatly appreciated. I have a Javelin R19, without a jackplate and 150hp motor. Plans are to install unit by console. My biggest question is on transducer location, I have tried to look at several pic and study info on site. Which is very helpful thanks to all. Thanks to all in advance.
Offline lineman
Re: NEW 998C SI HD SET-UP
« Reply #2 on: January 10, 2014, 09:42:25 PM »
Rickie thanks great link.
Offline Rotus623
  • Software: 6.49
« Reply #3 on: January 14, 2014, 10:41:18 AM »
What made you switch from Lowrance, and what unit did you have?
Offline lineman
« Reply #4 on: January 14, 2014, 05:52:47 PM »
Rotus623, I had the Lowrance 522c igps. The unit works great and I still have it on my boat. I wanted to upgrade to a side image unit and after research and pricing Humminbird worked best for me. I have not had a chance to put in on the water yet but hopefully all will work ok. I see you run the 898 if you have any pointers as for as setting you like feel free to share.
Chris B
Offline Rotus623
  • Software: 6.49
« Reply #5 on: January 14, 2014, 07:06:54 PM »
Go through all of the FAQs and info on interferences. There is soooo much info on here. I keep my SI about 3-4 times wider than the depth, and I like to keep the contrast up higher than most, like at 12-15 and keep my sensitivity low at around 7-8 with enhance on low. This really makes the fish stand out. Keep scroll speed matched to boat speed and record videos!!! Lots of them because you can find which settings you like while using playback.
Offline lineman
« Reply #6 on: January 14, 2014, 10:14:26 PM »
Thanks a lot!! It is a very informative site, more so than any I have seen. Thanks again
Last post June 21, 2010, 10:44:34 PM
Last post August 16, 2012, 03:15:01 PM
Last post November 19, 2012, 04:46:50 AM
by baker2605
Last post December 15, 2012, 12:10:23 PM
by Jim Jack
Last post February 02, 2013, 09:55:40 PM
Last post June 13, 2013, 09:03:32 PM
by johnnytherock
Last post June 11, 2013, 09:04:52 PM
Last post June 07, 2019, 08:26:36 PM
