Author Topic: XTM 9 HDSI 180 T display options  (Read 8081 times)
Offline D S
  • Software: 7.5
« on: January 10, 2014, 05:15:28 PM »
can I trick this transducer  to display the Si images as shown on the quadrabeam split screen in my manual for my 798 if I select quadrabeam in the menu selections??
 thought it might be good for ice fishing application.....or do I infact need a quadrabeam ducer for that display?
ps will it damage anyting if I try this setting??
ds
stgr
Re: XTM 9 HDSI 180 T display options
« Reply #1 on: January 13, 2014, 12:39:43 PM »
Dave,
Give it a try and see what you get – it should work as all of the same connections to the transducer are used though the programming will be different.  It should not hurt either the transducer or the unit.
« Reply #2 on: January 13, 2014, 07:17:14 PM »
And post a screenshot of what it looks like...
This is very interesting....
Offline D S
  • Software: 7.5
« Reply #3 on: January 13, 2014, 11:16:16 PM »
pic in simulator mode
wont be on ice till weekend will post examples after that
ds
stgr
« Reply #4 on: January 14, 2014, 01:13:14 AM »
I was going to ask if you had hooked up the SI transducer to your Matrix unit yet but I see you have a Matrix 27.  I think it was the Matrix 37 and up that had quadrabeam.
If anyone would like to try it, you get some very interesting results!  ;)
« Last Edit: January 14, 2014, 01:20:23 AM by RGecy »
Offline D S
  • Software: 7.5
« Reply #5 on: January 20, 2014, 05:07:04 PM »
tried the Quad view but  view on screen look too small on 798 for me to watch while ice fishing ..
so ended up going back to 2d  view with RTS window wide  max mode  outstanding while ice fishing i prefer it to then flasher view as it shows history for you
BTW  any onyone know the resolution of the flasher view for comparison sake?  vs the standard 2d in max mode??
dave
stgr
« Reply #6 on: January 28, 2014, 10:22:42 AM »
I think that the Circular Flasher View has 256 divisions while your 798 has 640 vertical pixels.
Last post December 25, 2009, 09:42:29 AM
by Deltaden
Last post January 10, 2011, 05:02:12 PM
by gobio
Last post January 12, 2011, 03:54:40 PM
by rclyatt
Last post May 12, 2018, 09:24:57 AM
by danlaboucane
Last post March 24, 2012, 09:25:37 AM
by BrianRHCT
Last post April 04, 2012, 03:50:28 PM
Last post June 13, 2013, 11:05:36 AM
Last post July 06, 2013, 01:04:08 PM
by theflatlander
