Author Topic: dual control head compatability  (Read 9046 times)
Offline coastalretention
  • Unit(s): 1199si, 1198c, 360 imaging, I pilot st
  • Accessories: 5 port, Radr Radom, I pilot link
« on: January 04, 2014, 10:03:25 PM »
I have an 1199 at my console and a 1198 on the bow connected thru a 5 port. I also have the I pilot link, I pilot st, 360 imaging and the radar radom. When I cut both units on I do not see wer the front unit is reading the Navionics Platinium plus card that is in the console control head. I there a setting I am missing or do I have to buy another sd card for the bow control unit. I thought this was the perpose of the 5 port so the info could be shared. Any advise is welcome.
Online rnvinc
Re: dual control head compatability
« Reply #1 on: January 05, 2014, 12:01:00 PM »
Maps cannot be shared in the HB units...
You will have to buy a second card for the other unit...
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #2 on: January 05, 2014, 06:25:54 PM »
You can share all other info except maps.
« Reply #3 on: January 05, 2014, 06:30:49 PM »
using the unit today I left the dock at 5:30 and found that the function key were not lit, only the cursor was lit. Is this normal or does this unit have a malfunction. The fish ID and Fish ID alarm are on and no sound would come from the unit. I could not find a volume setting as my 1198 has. could you comment on this if possible.
Offline LocDown
    • Fishing Videos
« Reply #4 on: January 05, 2014, 06:35:33 PM »
i don't think there's a volume setting but sound pitch setting, high, medium, or low pitch. As for the button backlighting, I think they should be all lit up. Try again later and see if they light up. I don't know what the temps are there but it might be something.
« Reply #5 on: January 07, 2014, 12:02:04 PM »
If all the buttons are not lit up then there is a problem with the backlighting for those buttons and the unit would need to be sent into Humminbird.  Call the Humminbird Select number to set this up.
Last post December 28, 2009, 03:03:38 PM
by soretoe
Last post June 13, 2012, 10:16:17 AM
Last post November 27, 2012, 02:33:00 PM
by BCLII
Last post August 15, 2013, 08:53:00 PM
by SuperG
Last post March 06, 2014, 04:40:54 AM
by fishermanatr
Last post January 28, 2015, 11:36:44 AM
Last post July 23, 2016, 04:47:26 PM
Last post May 08, 2021, 03:40:42 AM
by Rüdiger
