Author Topic: access is denied.[G:\MATRIX\PC_131105c.gpx]  (Read 9484 times)
Offline steelebob
  • 1994 TRACKER NITRO 160 and 4 cyl 2017 Yamaha 70 h
  • Unit(s): Helix 2nd gen 10 and 9
  • Accessories: Ulterra
« on: November 05, 2013, 01:28:23 PM »
When I try to open a NEW FILE in humpc, I get that message. So how would I open a new file?
I dream of things that never were, and ask why not?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: access is denied.[G:\MATRIX\PC_131105c.gpx]
« Reply #1 on: November 05, 2013, 03:53:10 PM »
Is G: the SD-card?  If so, maybe it's write-protected and move the SD-card tab so its not locked(write-protected).
While it's OK to put HBPC's GPX files on an SD-card, I would also have it on my PC hard-disk.
And maybe put the GPX files outside the MATRIX folder.
IMO
The HBPC default location of GPX is My Documents>My_HumminbirdPC>GPX_Files
« Last Edit: November 05, 2013, 03:55:21 PM by LittleGazoo »
Offline steelebob
« Reply #2 on: November 05, 2013, 04:00:20 PM »
Yea, I'm trying to think ahead just like that "Change Once, Save it 2ce, "
Offline LittleGazoo
  • Software: 3.640
« Reply #3 on: November 05, 2013, 05:05:50 PM »
So . . . Problem solved?
Offline steelebob
« Reply #4 on: November 05, 2013, 05:21:32 PM »
Not yet but I might have a work around. I don't have "My Documents>My_HumminbirdPC>GPX_Files[/b] ++ I'm tech challenged
« Last Edit: November 05, 2013, 05:25:21 PM by steelebob »
« Reply #5 on: November 07, 2013, 08:57:32 AM »
That is the default location that the HumminbirdPC program uses so you should have it when the program was installed.
Offline steelebob
« Reply #6 on: November 07, 2013, 09:17:33 AM »
So how would I get it to open a new file?
Offline LittleGazoo
  • Software: 3.640
« Reply #7 on: November 07, 2013, 11:21:21 AM »
Left-click the New File icon on HBPC's toolbar
Left-click File, select New, then left-click New File
Do you have the latest HBPC 4.3.8?
The above should create you a new empty GPX file named PC_yymmdda.gpx
Right-click on that file name, select Edit, then you can rename it.
« Last Edit: November 07, 2013, 11:24:31 AM by LittleGazoo »
Offline steelebob
« Reply #8 on: November 07, 2013, 11:42:47 AM »
And doing just that is when I get the error message I first mentioned. Access is denied.[G:\MATRIX\PC_1311....
I do have the latest HBPC 4.3.8
« Last Edit: November 07, 2013, 11:54:23 AM by steelebob »
Offline LittleGazoo
  • Software: 3.640
« Reply #9 on: November 07, 2013, 12:38:25 PM »
Is the G: drive your SD-card reader?
Left-click Edit, then Left-Click Preferences and under the General Tab see what the GPX file location says.
IMO, it should be set to the default My Documents\My_HumminbirdPC\GPX_Files location on your PC hard-drive.
You might have My_Documents or Documents depending on your Windows version.
G:\MATRIX folder might now not be a valid folder path.  This location must be a existing folder.
« Last Edit: November 07, 2013, 12:41:44 PM by LittleGazoo »
Offline steelebob
« Reply #10 on: November 07, 2013, 02:27:12 PM »
Problem Solved. GaZoo strikes AGAIN!!!
Last post April 22, 2009, 03:56:35 PM
by Keith Councell
Last post April 11, 2010, 12:47:59 PM
Last post May 05, 2011, 07:43:52 AM
by inshorecatch
Last post May 10, 2011, 04:16:20 PM
Last post November 23, 2011, 12:38:31 PM
Last post March 22, 2012, 11:13:23 AM
Last post June 27, 2012, 02:46:43 PM
Last post May 13, 2015, 03:45:34 PM
by MGEOD
