Author Topic: Viewing snapshots  (Read 9167 times)
Offline Umbutu
  • Unit(s): 798CI SI
  • Software: 6.3
Viewing snapshots
« on: November 01, 2013, 01:00:59 PM »
Yesterday when I was out I took a lot of snapshots of some structures from different angles. I also took a few snapshots of new things I found and then changed the file name from S*** to a familiar waypoint name. I can still see those S*** file names on the SD card in HumminbirdPC but if I look at the "Snapshots" directory from the SD card on my computer they are not there. They also don't show up in the Humminbird unit's viewer. Is there a way to view those "S" files?
Re: Viewing snapshots
« Reply #1 on: November 02, 2013, 08:43:04 AM »
If all you did was rename the snapshot files, than they should still be where they were at and still be *.png files.  You should still be able to see them on your computer.  If they are not in the Snapshot file then you must have moved or deleted them.
Offline ezfishn
« Reply #2 on: November 14, 2013, 08:08:12 PM »
if you change the file names off the unit on a computer will the unit still recognize the files or do you need to change them on the unit?
« Reply #3 on: November 15, 2013, 03:05:34 PM »
If you change the Screen Snapshot *.png file names on your computer and load them back to the SD card, the unit will still be able to display them as they will still be in the *.png file format.
You cannot change the Screen Snapshot name with the unit.
« Reply #4 on: November 15, 2013, 03:37:45 PM »
This is from a post last year when I was testing some of this......
OK, I did some testing to see how far I could go with this......
If you rename a snapshot's waypoint it DOES NOT rename the snapshot image.  This we know. And the snapshot preview will still come up when you move cursor over the waypoint, even though the waypoint name and snapshot name are not the same.  Hit the info button and View Snapshot and the full size shapshot comes up as well.
So the snapshot is not being reference by name, its being done by the GPS coordinate in the .DAT file of the Snapshot.  I performed a test to confirm this by switching the headers of two .DAT files and they both reversed the snapshots and preview images. Confirmed.
Also, you CAN rename a snapshot and have it display the preview image and snapshot correctly, just as long as you rename both the .PNG and .DAT to the same name.  However, when viewing it on the RECORD/SNAPSHOT screen, the file name would not be correct.  This is because the gps info, date, and displayed file name on that screen is read from inside the .DAT file.  In order to change this, you would need a hex editor program.
I even renamed one shapshots .DAT and .PNG files to Shipwreck123456789 to see if name length mattered and it worked fine when viewed on the unit.  However, the internal name length is limited to 10 Characters.
So, in conclusion.  It is OK to rename a Snapshot Waypoint and not rename the snapshot.  And it is OK to rename a Snapshot, just as long as you rename both the .DAT and .PNG file.
Last post December 14, 2010, 07:09:31 PM
Last post November 27, 2011, 01:02:19 PM
Last post April 29, 2012, 03:16:16 AM
by Rüdiger
Last post March 16, 2015, 12:48:33 PM
by SkeeterMatt
Last post August 04, 2013, 05:28:44 AM
by Rafael
Last post October 15, 2013, 11:19:28 PM
by LittleGazoo
Last post March 25, 2014, 11:33:54 AM
Last post February 20, 2015, 11:00:05 PM
