Author Topic: making a cross section  (Read 15519 times)
Offline j2000
    • Hummibird Indonesia
  • Unit(s): 798CI SI HD
« on: October 25, 2013, 09:14:14 PM »
Hello .. I am using 998csi. Is accurate for a range of values ​​on the right side and the left, if the average river depth of 3-7 meters and the average river width of 30 to 60 meters?
What is the best setting for SI range, i set for 70 meter or auto ?
This relates to determining the value of "cross section" at any point that I will make later.
Joel
humminbird.co.id
Re: making a cross section
« Reply #1 on: October 28, 2013, 09:14:11 AM »
I’m not real sure what you are asking here Joel.  Your 798 unit should be able to work in 3 to 7 meters of water and out to 60 meters in width at those water depths.
I would use a steady manual setting like 70 meters if I wanted to see how the sides of river were shaped.  However, using a smaller Si Range setting will increase the viewable Si sonar resolution on the unit itself.  I don’t like the SI Range on a unit automatically changing on me because I would have to constantly look to see what the range is set at and factor that into my brain when I’m looking at the Si sonar readings.
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
« Reply #2 on: October 28, 2013, 01:19:34 PM »
or set it for 30 meters if you go down the middle of the river... ;)
« Reply #3 on: October 28, 2013, 03:35:35 PM »
That would be even better!  ::)
Last post April 02, 2009, 08:43:54 PM
Last post October 14, 2010, 06:35:55 AM
by ElvisMarcy
Last post April 15, 2012, 12:01:10 PM
Last post November 06, 2012, 10:35:24 AM
by Bobcat316
Last post October 23, 2013, 09:31:26 AM
by j2000
Last post April 05, 2015, 11:17:01 AM
by nwifishnut
Last post January 20, 2023, 06:14:07 AM
by danlaboucane
Last post May 04, 2023, 12:19:45 AM
by Walter
