Author Topic: 898c Flaking Out - Help  (Read 4220 times)
Offline msrussel
  • Unit(s): 898c HD SI Combo
« on: August 31, 2013, 08:06:08 AM »
I'm having significant issues with my 898 unit. About a month ago, it started getting stuck in one zoom level in the chart view. Zoom In and Zoom Out then doesn't work, they beep but don't zoom at all. I also cannot push the View button - when I do, the unit reboots. I can push the Exit button to go back through the displays, but not View. Also once it enters this mode, I cannot record the session.
Has anyone seen this? I am able to clear the problem out if I reload back to the older software, then reload the new software on the unit, but that's a real pain.
I called Humminbird and they said for me to send the unit in - I just hate to be without it for a couple weeks at this time of year (prime fishing season in the Lowcountry), so I was wondering if anyone else had seen this and if a more permanent fix was available without sending to Humminbird. BTW - they really need to get a more modern customer support system - I can't believe that when a unit is under warranty (which mine is), they won't send you a new one and have you send back the flawed one. I pushed hard to get them to do this, but they wouldn't. I've had two kindles flake out and amazon sends new ones - no questions asked, if they are under warranty.
Anyway - please let me know if anyone has seen this problem. My guess is that I'll have to send it in - sounds like a hardware/software issue with the unit itself. BTW - I do love this product, just wish it would work all the time. I'm still learning to use it though, so look forward to learning from this forum.
Thanks, Mark
Offline Gattlin
Re: 898c Flaking Out - Help
« Reply #1 on: September 03, 2013, 10:41:57 PM »
 Anytime I hear unit reboots makes me think. Power supply issues. My units have rebooted on a number of occasions the first few times were because I had to low of voltage running from the fuse panel on my boat. So I wired direct to my battery with an inline 3a spade fuse and I believe16G wire. Problem was solved. I do not unhook my units from my boat when I get home. If you connect unconnect all the time there can be some wear at the pins of the Unit where the power connects, a slight very slight bend on the pins might help with power if that's the case. The other issue of rebooting for me is of a firmware conflict between my two units over the Ethernet the newer firmware at the console doesn't like the older firmware at the bow. If I updated the firmware at the bow I suspect this will go away. But I will not as that firmware seems to give me a better picture. than the newest firmware at the moment. Good luck and tight lines Gat
Just one last cast.
Last post April 12, 2010, 06:30:09 PM
by tennwalkinghorse
Last post January 25, 2011, 10:39:26 AM
Last post January 30, 2011, 11:49:20 AM
Last post January 30, 2011, 02:20:17 PM
Last post May 02, 2011, 05:44:33 PM
by Helge23
Last post June 01, 2011, 11:22:58 AM
Last post October 19, 2012, 07:49:11 AM
by RivRunR
by raypla
