Author Topic: Gps signal loss  (Read 12257 times)
Offline DiNozzo
Gps signal loss
« on: August 17, 2013, 07:11:02 AM »
Hallo
after i connectet the 1197c SI and SAILOR 6215 with DSC with teh "pig tail" to get gps posistion on the VHF the 1107 losses the gps signal after 10-15 min and i have to power off and on for it to work (i did turn on the nmea in the advance menu and the VHF is reciving af signal) if i turn off the nmea output on the 1197, it dosent loos the gps signal.
hop anyone can help
Re: Gps signal loss
« Reply #1 on: August 20, 2013, 02:31:20 PM »
Welcome to the Humminbird Side Imaging Forums DiNozzo.
What wires did you connect from the NMEA pigtail wire to your VHF radio?
Offline DiNozzo
Re: Gps signal loss
« Reply #2 on: August 21, 2013, 03:25:34 PM »
i have connectet the with and black to the VHF...
Offline DiNozzo
Re: Gps signal loss
« Reply #3 on: August 21, 2013, 03:43:37 PM »
as shown int the attach files i have connectet the brown from the VHF to the white in the "Pig Tail" and the Blue from the VHF to the Black from teh "Pig Tail"
Re: Gps signal loss
« Reply #4 on: August 22, 2013, 01:35:35 PM »
You may want to try connecting to the Black NMEA pigtail wire to the radio's ground.
Offline DiNozzo
Re: Gps signal loss
« Reply #5 on: August 26, 2013, 05:52:39 AM »
Hallo
and thx for the reply
i have tryied to connect as you wrote but with no luck the only way the VHF is getting af gps signal is when i connect them as i wrote.
Re: Gps signal loss
« Reply #6 on: August 30, 2013, 02:05:32 PM »
Not sure what is going on than DiNozzo.
Anyone else have any suggestions?
Offline DiNozzo
Re: Gps signal loss
« Reply #7 on: November 04, 2013, 11:13:09 AM »
could it be a sorftware glitz and would a update fix it..?? and where do i see the sorftware version
Re: Gps signal loss
« Reply #8 on: November 05, 2013, 09:01:53 AM »
The NMEA output works fine on some other radios so I do not think that it is a software glitz on our end.
The software version of your unit can be seen by setting the Self Test View to “Visible”.  This is done under the Views menu tab.  You will then have to scroll through all of the available Views until you get to it.
Offline DiNozzo
Re: Gps signal loss
« Reply #9 on: January 19, 2014, 11:19:18 AM »
hey
here you can see the the sorftware version, do you think i will get any improvements if i upgrade..??
Re: Gps signal loss
« Reply #10 on: January 28, 2014, 10:38:41 AM »
No I do not.
Last post July 11, 2010, 08:11:39 AM
Last post September 17, 2017, 05:08:10 AM
by abraquelebout
Last post April 30, 2012, 04:51:39 PM
Last post February 14, 2013, 10:58:13 AM
Last post August 02, 2013, 11:16:29 AM
by tanman
Last post September 16, 2013, 07:33:41 PM
by Alloutdoors
Last post June 13, 2017, 10:35:59 PM
Last post April 22, 2019, 10:59:40 PM
