Author Topic: B000 error  (Read 13337 times)
Offline N9Phil
B000 error
« on: August 14, 2013, 09:04:20 PM »
When trying to load data from the record file I receive the error Booo should contain data for approximately 21508 seconds but contains data for 4 seconds.  Other data could be corrupted also.   After continuing I try to run with the loaded data and the remaining data in corrupt.    I am recording on  1198 CSI unit using the latest software.   Is it possible that the latest upgrade is the problem?   Does anyone have any suggestions to the problem?    This has happened the last 3 times out.
Phil
Offline N9Phil
Re: B000 error
« Reply #1 on: August 14, 2013, 10:38:05 PM »
I still get the error but I am now able to see my data.   I reloaded Java and removed and then reinstalled Humviewer this time just installing the program alone.    I also have to readjust the cropping setting each time that I load a new data file.   Is there any help file around that I might read that explaines settings and how to set up the program?
Thanks,
Phil
BrazosRiverTom
  • Guest
Re: B000 error
« Reply #2 on: August 30, 2015, 05:01:33 PM »
I am getting the same error code, does anyone have any ideas what this is and how to make the code go away?
Re: B000 error
« Reply #3 on: August 30, 2015, 08:54:54 PM »
Are you manually stopping the recording process on the HB unit by selecting "Stop Recording" from any Xpress menu ... ??
BrazosRiverTom
  • Guest
Re: B000 error
« Reply #4 on: September 01, 2015, 04:00:26 PM »
No this is happening while humviewer trys to open/download the recording. You can see it going B0001,  B0002, B0003, then GPS.  Then it gives you the error code on B0000.  The file on my computer opens and does run.  It is just annoying to get the error code and not know if it is really affecting the file.
BrazosRiverTom
  • Guest
Re: B000 error
« Reply #5 on: September 01, 2015, 04:04:02 PM »
Sorry I reread your question.  Yes I do stop the recording on the Humminbird unit.  I do not know or remember if I stop it from an Express Menu or not. I think I do, I hit menu and on the express screen at the top I think it said Stop Recording  and I did.
Re: B000 error
« Reply #6 on: September 02, 2015, 04:23:32 PM »
This is correct ... Once starting a recording from the "Snapshot and Recording" view ... The recording process can be manually stopped by pressing the "Menu" button one time from any view (Not diagnostic views)... And "Stop Recording" will be at the top of the list in the Xpress menu ...
So the recording is loading and playing in Humviewer ... ??
But you are getting the error code for the B0000 ...??
Is it possible you are changing the the "Beam Frequency" setting (under the Sonar tab on the HB unit) while the recording process is "recording" ... ??
« Last Edit: September 02, 2015, 04:24:43 PM by rnvinc »
BrazosRiverTom
  • Guest
Re: B000 error
« Reply #7 on: September 04, 2015, 09:12:53 PM »
I suppose it is possible as I recently started messing around with that.  I am not gonna worry about the error code as once humviewer tells me the B000 error, the movie still runs and it looks complete to me.
Re: B000 error
« Reply #8 on: September 05, 2015, 12:09:41 AM »
Just a FYI ...
The B0000 file is the 83kHz frequency channel ...
*If you started the recording with the "Beam Frequency" setting at 83kHz or 83kHz/200kHz ...and then changed the "Beam Frequency" setting to 200kHz during the recording (turning off the 83kHz channel) = the recording would not have an "end data" reference point for the 83kHz channel at the "Stop Recording" command ...
*If you started the recording with the "Beam Frequency" setting at 200kHz ...and then changed the "Beam Frequency" setting to 83kHz or 83kHz/200kHz during the recording (turning ON the 83kHz channel) = the recording would not have an "start data" reference point for the 83kHz channel at the "Start Recording" command ...
« Last Edit: September 05, 2015, 12:11:50 AM by rnvinc »
Last post December 17, 2009, 11:37:18 AM
Last post January 31, 2011, 01:31:22 PM
Last post September 10, 2012, 08:52:40 AM
by gros21
Last post December 11, 2012, 02:33:03 PM
Last post December 12, 2013, 10:09:49 AM
by steelebob
Last post May 01, 2014, 11:23:46 AM
Last post April 24, 2014, 04:36:22 PM
Last post June 12, 2015, 10:29:31 AM
by D S
