Author Topic: Need to Downgrade my 958...any older FW available?  (Read 10542 times)
Offline KBarr
  • Unit(s): 1198, 958
  • Software: 6.610
« on: August 04, 2013, 03:55:25 PM »
Greetings,
I upgraded my bow mounted 958c DI to 6.680.  As usual, the HB FW is junk.  Are there any older versions of FW available?  I tried logging onto my account at HB.com but server is crashed.
Thanks,
Signed:  Wishing I stayed with Lowrance  :(
Re: Need to Downgrade my 958...any older FW available?
« Reply #1 on: August 05, 2013, 12:14:14 PM »
Do you know what version software your unit had before you loaded the 6.680?
Send me a direct e-mail requesting that version of software and I can send it back to you via TransferBigFiles.com
If you do not know what version software you had in your 958c DI unit before loading the 6.680 then e-mail me the serial number of your unit and I can get the Humminbird CRC folks to look up what software it was originally manufactured with and either send it to you or one in between it and the 6.680 version software.  You should also be able to call them and get the same.
Offline KBarr
  • Software: 6.610
« Reply #2 on: August 05, 2013, 02:42:36 PM »
Greg,
Thanks for the help, I will get the SN this evening.  Humminbird is lucky to have you as support, you are the only person I have found who knows the products.
Regards,
Kevin
Last post June 03, 2012, 10:58:02 AM
by Roddy
Last post June 10, 2015, 10:41:10 PM
by FlyFisher SLC
Last post June 14, 2015, 11:00:13 PM
Last post January 23, 2017, 01:52:04 PM
by Mark Saikaley
Last post July 20, 2022, 08:24:25 PM
Last post August 18, 2019, 12:21:38 AM
Last post February 15, 2020, 02:22:12 AM
Last post March 29, 2024, 02:37:01 PM
by proskeeterman@comcast.net
