Author Topic: transducer trouble?  (Read 5206 times)
Offline randy voth
  • Unit(s): 798
transducer trouble?
« on: July 30, 2013, 02:33:33 PM »
The depths from my 798 are reading far deeper than the actual depth. Example: 500ft. when I know it's only 20ft. I checked the transducer and it's mounted solid, not loose. I am getting the correct temp and speed. Is there anything else I can check or do or do you think maybe I have  to change transducers. Appreciate any help!
Re: transducer trouble?
« Reply #1 on: August 02, 2013, 01:11:12 PM »
Welcome to the Humminbird Side Imaging Forums randy voth.
I would try testing your 798 unit on someone else’s boat that has either a Humminbird Si model unit or one of our standard sonar units (not a DI model unit) and see if the unit reads the correct water depth.  If it does than I would also test their unit on your boat.  Take the cables out of the mount and plug them in by hand if you have to, to test them.
Offline Speedtroller
  • Unit(s): 798ci SI
  • Software: 5.840 6.300
« Reply #2 on: August 11, 2013, 03:30:26 PM »
Is this while you are running on plane or when you are going slow. Post a picture of how and where your transducer is mounted.
Fishing, a jerk on one end, waiting for a jerk on the other end !!!
Last post January 17, 2010, 10:40:49 PM
by DTG
Last post April 03, 2010, 10:12:01 AM
by Ankrum
Last post April 14, 2010, 09:24:45 PM
by Gillfisher
Last post February 27, 2011, 08:57:59 PM
Last post April 12, 2011, 06:01:33 PM
by Scrutch
Last post August 02, 2011, 12:59:21 PM
Last post February 14, 2013, 01:33:57 PM
by bobxxx
Last post September 19, 2013, 09:34:28 AM
by Rickard
