Author Topic: dr depth not showing side scan  (Read 19743 times)
Offline goodwinexplorer
  • Unit(s): 1187, 1198,c si combo
  • Software: 4.18
« on: July 26, 2013, 12:48:55 PM »
i am having trouble getting dr depth to work the scan mosaic is greyed out, it says cable connected and reads gps, i have herd that there are issues with some soft where upgraded s ie.6.6, could this be my problem?
Offline abraquelebout
Re: dr depth not showing side scan
« Reply #1 on: July 27, 2013, 06:14:44 AM »
hi
as your problem come after upgrading your unit.?
i get a problem like this, after upgrading drdepht every thing are ok.
hey per come back !!!!
  • Software: 4.18
« Reply #2 on: July 29, 2013, 05:01:38 AM »
i tried to up grade using my link, but is is locked as he has sold the company?
have you found another way to up grade
« Reply #3 on: July 29, 2013, 06:41:15 AM »
for the last version go on user site for drdepht
i don't know if it's work
after you can go on anterior upgrad to your unit
  • Software: 4.18
« Reply #4 on: July 29, 2013, 08:54:35 AM »
Thanks for that i downloaded 5.1 say upgraded to work with new humminbird information
Offline Rüdiger
« Reply #5 on: July 30, 2013, 02:21:57 PM »
hi
I think your firmware version is the problem. To my knowledge, the 6.6er version is no supported. So you have to go back in the firmware version.
mvh
Rüdiger
Finding is better than losing
  • Software: 4.18
« Reply #6 on: July 30, 2013, 02:46:06 PM »
so the dr depth will not work with 6.6? i had 6.18 huminbird and it did not work with 4.18 dr depth, what version have you got to work?
Offline Rüdiger
« Reply #7 on: July 31, 2013, 01:54:52 PM »
hi
I use DrDepth 5.1.8 BTSS and 5.4 as firmware of HB.
Now I have sought and read in DrDepth forum that the HB firmware up to 6.49 is supports .
mvh
Rüdiger
Offline D S
  • Software: 7.5
« Reply #8 on: July 31, 2013, 02:17:50 PM »
I currently run Drdepth5.1.8SS and HB 6.49 on 1198 works fine
ds
stgr
  • Software: 4.18
« Reply #9 on: August 01, 2013, 03:05:06 AM »
thanks i have just up graded to 5.4 dr depth but is asking for the internet for code i have the code from last time do i need to go back the par? i do not have internet on the boat, or is there a way round it i can not see?
bob
Offline Rüdiger
« Reply #10 on: August 01, 2013, 02:40:17 PM »
hi
DrDepth 5.4? I know only of 5.1.8
mvh
Rüdiger
  • Software: 4.18
« Reply #11 on: August 01, 2013, 02:56:08 PM »
type error, i see par say down load data if you do not have the internet however on his web site the support is not working, so i will try and tether my phone
  • Software: 4.18
« Reply #12 on: August 03, 2013, 10:54:40 AM »
my 1197 came back with 6.6 soft ware, last time i tried to wind it back it crashed, tried dr depth 5.5 same problem  in scan the mosaic is grayed out, will humminbird upgrade dr depth now they own it to work with there latest software?? if so when?
« Reply #13 on: August 04, 2013, 03:11:13 PM »
hi
can you make a screen capture of your problem with drdepht and post it,?.
i have not the same thing, before upgrading drdepht, it's not showing mosaïc.
all thing are ok now it's why i'm not upgrade my 898 after this problem.
drdepht is a nice soft and i don't want to loose it !
Offline Rüdiger
« Reply #14 on: August 05, 2013, 03:12:30 PM »
hi
If you want to use DrDepth 5.1.8 you will have no choice but to reset your unit to 6:49.
Whether Jonson's Outdors, the new owner of DrDepth, will update the software and this for free :( , I do not think so, but remains to be seen.
 mvh
 Rüdiger
  • Software: 4.18
« Reply #15 on: August 06, 2013, 01:08:55 AM »
thanks for that, i try winding on back
  • Software: 4.18
« Reply #16 on: August 06, 2013, 01:13:51 AM »
the only problem is that there is not a 6.4 for the 1197 what about 6.18 as they are both available for the 1198 and the 1197?
Offline Rüdiger
« Reply #17 on: August 06, 2013, 03:58:32 PM »
hi
The main thing is not higher than 6:49, deeper is not a problem.
Ask Greg where you can download the appropriate firmware.
mvh
Rüdiger
Last post April 07, 2009, 12:48:02 PM
Last post August 08, 2011, 02:09:33 PM
by lolar3288
Last post November 21, 2011, 04:37:29 PM
Last post December 13, 2013, 05:38:31 AM
by peterv6i
Last post December 09, 2013, 02:58:50 PM
by peterv6i
Last post December 21, 2013, 11:03:29 PM
Last post August 03, 2019, 11:22:25 PM
by Gimp
Last post June 27, 2023, 09:07:12 AM
by oschi
