Author Topic: Newbie with some problems.....  (Read 7957 times)
Offline flocknocker
  • Unit(s): 998
« on: July 14, 2013, 02:39:41 PM »
Getting some "white Lines" on my unit when trying to use the DI screen....Any advice??
Offline johnnytherock
  • Unit(s): 998si, matrix 20,
Re: Newbie with some problems.....
« Reply #1 on: July 14, 2013, 05:55:05 PM »
first thing to do is make sure absolutely everything on the boat is turned off, if the problem goes away,  turn things on one at a time to see which is the culprit.  may even be the charging system on the motor?   start there.
« Reply #2 on: July 14, 2013, 11:18:57 PM »
This anomoly has been reported with the newer software versions and seems related to the "DI Enhance Sharpness" being set to any setting above "Off"...
With the DI view showing ... Press the menu button 1 time to open the Xpress menu...
Cursor down to "DI Enhance" ...
Cursor right to opent the "DI Enhance" subwindow ...
Set the "Sharpness" to "Off"...
HB does know about this and hopefully they are working on a fix ...
Report back if this doesn't fix your issue ...
« Reply #3 on: July 16, 2013, 11:50:20 AM »
Welcome to the Humminbird Side Imaging Forums flocknocker.
Rickie is right, turn off the Sharpness for the DI sonar and it should go away.
Last post March 22, 2010, 10:07:42 PM
Last post April 18, 2010, 11:00:46 PM
by hhisland
Last post September 30, 2010, 06:29:25 AM
by FuzzyGrub
Last post December 04, 2010, 05:35:33 PM
by Enufzed
newbie
Started by adam1886 898c SI
Last post July 12, 2011, 10:34:39 AM
Last post May 24, 2012, 02:12:39 PM
by RickT
Last post July 08, 2012, 05:37:42 PM
by hawgdog
Last post September 14, 2012, 06:51:36 PM
by scags176
