Author Topic: 6.68 update results  (Read 8818 times)
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
6.68 update results
« on: June 23, 2013, 06:26:23 PM »
Had a real chance to try out 6.68 today to see if I could get back what I lost in the last couple of updates as it relates to image quality.  I am not going to it is all gravy but after really trying at it I was able to get images that were acceptable.  I found I had to crank the contrast up to around 12 and adjust the sensitivity accordingly.  I was able to mark the individual rocks around the bridge and mark my boat trailer on the ramp.  Next time out I will play with my 1198 to see how good it can get.
Offline maachuu
  • Unit(s): 898si -998c HD SI - Piranha Max 150
Re: 6.68 update results
« Reply #1 on: June 23, 2013, 08:35:01 PM »
thanks for the info cookie. I was told yesterday that if I would run my 998c HD on the "saltwater" setting that it would give better quality versus the "freshwater" setting. Have you heard of this ?
thanks
maachuu
ASAP - Always Say A Prayer
Offline LittleGazoo
  • Software: 3.640
« Reply #2 on: June 23, 2013, 10:18:58 PM »
If you can test the 2D sonar with different Chart-Speeds.
I have a 1197 and my 2D sonar looks good with CS at 1 or 2, but degrades badly at 5 and higher.
In the past, I would run a Chart-Speed of 10 when drop-shot fishing.
Offline lcookie
« Reply #3 on: June 30, 2013, 08:59:43 PM »
thanks
maachuu
Have not heard of this but will try out next time
Offline lcookie
« Reply #4 on: June 30, 2013, 09:03:11 PM »
I ran mine up to about 6 and it looked good to me.  I like to run 1 to 2 settings higher than my boat speed to help the images pop and my boat speed was 2 to 4 mph.  Did not go any faster than that.  This is much improved from the pervious update.  My images sucked an any chart speed.
Offline Bombercraw
  • Unit(s): 998C SI
« Reply #5 on: July 01, 2013, 04:43:32 PM »
I just purchased a 998C HD SI about a month ago.  How can I tell what version of software is on my unit to know if I need the latest software update?
« Reply #6 on: July 02, 2013, 01:45:11 PM »
With your unit on and running; press the MENU button twice to get to the main tabbed menu system.  On the right side should be a “Views” menu tab.  Go to it and scroll most of the way down the list until you see the Self Test View and set it to “Visible”.  Get out of the menus and use the VIEW or (EXIT) button to see the new View.  It should show what software version the unit is running.
Offline Bombercraw
  • Unit(s): 998C SI
« Reply #7 on: July 05, 2013, 11:18:44 AM »
Thanks for the info Greg !!! :)
Last post December 15, 2010, 04:38:33 AM
by bmft01
Last post May 26, 2010, 01:17:35 PM
by abraquelebout
Last post December 19, 2011, 12:43:59 AM
by LocDown
Last post March 08, 2012, 06:29:06 AM
by alnash
Last post September 15, 2012, 12:28:41 PM
Last post April 15, 2013, 11:02:44 PM
by KeggER420
