Author Topic: double echo is it good or bad?  (Read 8887 times)
Offline deyo27
  • Unit(s): 798 598
« on: June 01, 2013, 12:43:02 AM »
I get a double echo some times and it affects the depth reading. So should I just get used to it or is my transducer set wrong?
Re: double echo is it good or bad?
« Reply #1 on: June 03, 2013, 11:34:32 AM »
Double echo as in you can see the second sonar return but the unit is still showing the correct digital water depth…
or..
double echo as in the unit is showing the second return as the actual water depth on both the digital depth and the sonar chart?
If it is the second; try turning on and up the Surface Clutter menu.  If you have another sonar unit running at the same time; try turning it off first to see if what you are experiencing is due to sonar interference.
Offline deyo27
  • Unit(s): 798 598
« Reply #2 on: June 06, 2013, 09:40:58 AM »
I will try to get a picture tomorrow.
Last post October 13, 2009, 09:29:33 AM
Last post September 10, 2010, 10:59:59 AM
Last post January 11, 2015, 10:00:52 PM
Last post May 28, 2015, 12:19:53 AM
Last post July 09, 2015, 01:00:42 AM
by CamoHunter
Last post November 28, 2015, 10:25:05 PM
Last post May 20, 2016, 11:39:51 PM
Last post August 05, 2022, 02:25:40 AM
by October1
