Author Topic: hdsi on 798 improvement over old transducer  (Read 6173 times)
Offline D S
  • Software: 7.5
« on: May 30, 2013, 11:53:27 AM »
just tried new transducer on 798 last night .
i swapped out original for HDSI  and the improvement is substantial,
but  a question for others ??
 to get optimum image i t seems as though i need to go a little faster  about  2mph or more  and also have  the screen speed  higher then what i prevously used .......
this may be a bit of a problem  for me ........
any suggestions on what parameters  to adjust as i usually drift in the river moving 1 to 1.5 mph and the image isnt quite as good.
most threads / DV say to set screen speed same as speed of boat but seems i need a faster screen speed to get the great images
DS
stgr
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: hdsi on 798 improvement over old transducer
« Reply #1 on: May 30, 2013, 11:42:37 PM »
Are you drifting straight or sideways? Are you recording while scanning? You might have to bump the chart speed up to correct for that.  I usually set chart speed 1 up to 2mph when not recording and up to 2-3 clicks higher when recording.
Offline D S
  • Software: 7.5
« Reply #2 on: May 31, 2013, 01:13:44 AM »
straight ...and I didn't realize that recording would cause you to need to increase the screen speed??
I will have to try again while not recording.. any other parameters I should change?......
cheers
ds
stgr
Last post March 26, 2010, 08:32:36 AM
Last post May 11, 2010, 07:09:23 AM
Last post April 27, 2011, 02:15:58 AM
by Roddy
Last post December 07, 2012, 07:52:12 PM
by reddog
Last post January 09, 2013, 02:46:33 PM
Last post October 18, 2013, 07:20:43 PM
by Kokanee
Last post February 25, 2014, 12:13:35 PM
by silvercloud
Last post January 27, 2015, 10:32:43 PM
by Fredfx21
