Author Topic: Networked two 998's  (Read 15348 times)
Offline promapper
  • Unit(s): 997C SI, 2-998C HD SI, 596C-HD-DI
  • Software: as of 5-08-13
  • Accessories: AS 360, I-Pilot Link, InterLink,Navionic
Networked two 998's
« on: May 27, 2013, 10:22:51 AM »
Just an observation...
I networked 2 998's together and I am just blown away by the sharing of data between the two.  I think this is one idea that HB got right!  A great addition to my toy box.
GPS receivers, transducers, waypoints, AS360, I-Pilot Link and I am sure other things I haven't found yet are accessible from either unit.  I can add waypoints on either unit and they immediately show up on the other unit.  Navigation to the WP works seamlessly as well.
It lets me run a primary unit as SI full screen and the secondary as navigation only or add the high speed transducer.
Since the SI transducers are above the waterline at speed I installed the XNT-9-20 (Per HB Greg's recommendation) on the secondary.  A quick on off of the dual beam XNT-9-20 at throttle up or down  can be accomplished just using the power switch thereby eliminating the interference of the dual beam to the SI when I return to idle or trolling speed
If you have two units that can be networked I would highly recommend it .
Greg
Last post May 24, 2011, 10:37:08 AM
by edwardpic
Last post June 15, 2012, 05:51:08 PM
by rdolson
Last post June 11, 2015, 11:33:44 AM
by johncos
Last post May 29, 2018, 09:31:10 AM
Last post August 27, 2018, 09:59:29 PM
Last post December 27, 2018, 04:17:20 AM
by Mark Saikaley
Last post April 30, 2020, 08:18:35 AM
