Author Topic: Help with Humminbird 598  (Read 5742 times)
Offline johnny337
  • Unit(s): 598CI
« on: May 24, 2013, 09:29:29 PM »
Hi. I just install my Humminbird 598CI Si combo. I went on the test run, at first it was working showing the side imaging. As I go half way the lake, the screen is starting to show white line through the middle of the screen and it would show a blank screen with 155ft when I'm only on 4 ft of water but it still reads the temp. and the mph correctly. I touch the transducer and it would work than at time it would not work again. What can be the problem?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Help with Humminbird 598
« Reply #1 on: May 24, 2013, 09:58:09 PM »
Were you viewing the SI view screen and was the Range set at a high number when this happen?
In 4', try bringing the SI range in to 25' and see what happens.
Offline Yrral3215
  • Unit(s): 598ci hd si
  • Software: stock
« Reply #2 on: May 25, 2013, 12:33:08 AM »
If touching the transducer makes it work for a while, sounds like you have a broken wire near that point or maybe a bad transducer. Did you pinch or nick the cable when installing it?
Last post May 03, 2010, 02:21:19 AM
Last post July 14, 2011, 04:30:42 PM
Last post January 20, 2012, 06:49:21 PM
by iliveinakeg
Last post January 03, 2012, 09:13:13 AM
Last post March 07, 2012, 10:31:22 AM
by jazz4627
Last post August 20, 2012, 09:39:53 AM
by Jim Jack
Last post November 08, 2012, 06:54:42 PM
by mel
Last post December 19, 2012, 05:10:47 PM
by Wallin
