Author Topic: Software Update Proceedure Warning  (Read 9377 times)
« on: May 15, 2013, 08:07:08 PM »
I am posting this because there has been discussion on here in the past about the correct procedure when doing a software update......Specifically whether to insert the card before powering up, or wait til the unit is powered up and then insert the card.
I have seen reports on other forums that the unit....the 1197 in this case....may be corrupted if the card with the update is inserted before powering up the unit.
(This is with the latest software update, but I think it would be prudent to apply the warning to any update.)
« Last Edit: May 15, 2013, 08:09:08 PM by Bob B »
Re: Software Update Proceedure Warning
« Reply #1 on: May 15, 2013, 09:41:25 PM »
Some time back a member (ITGEEK, I think) had a very interesting concept on this very discussion...
Allowing the unit to fully boot up before inserting the update card would be less "taxing" on the system than inserting the update card before power up....thus forcing the unit to try and update at the same time the unit is booting up...
« Last Edit: May 15, 2013, 09:45:13 PM by rnvinc »
Offline werethefugowee
  • Unit(s): 997si
  • Software: Downimaging
  • Accessories: speed
« Reply #2 on: May 15, 2013, 10:24:34 PM »
The way I do any update on my 997 is
Remove any  or all cards.
Boot up the unit.
Return EVERYTHING to DEFAULT.
Turn off unit.
Insert update card.
Boot up unit and let it do it's thing.
Worked everytime with no problems.
Offline TroyBoy30
  • Unit(s): 1198
« Reply #3 on: May 16, 2013, 07:48:24 AM »
you have to insert the sd card with the update on it after the unit is running.  it will no longer update if you insert it and then power it on.  it wont corrupt anything, the unit will simply not see the update
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #4 on: May 16, 2013, 09:05:58 AM »
HB support says to insert the Update SD into a running 1197, but they did not seem to know this until canadabullet and myself called in after trying to update to the 6.640 release.
We had the same symptoms.  After Restore Defaults, then powered down.  When powering up with SD inserted the SD update was detected, first update screen displayed and answered, but the second update continue screen was never displayed.  My unit booted into normal mode after hitting exit key.
Later, by inserting SD update into running unit, the 1197 was updated.
« Last Edit: May 16, 2013, 09:09:14 AM by LittleGazoo »
« Reply #5 on: May 16, 2013, 02:54:07 PM »
Installing the SD card with the update in it before or after the unit is up and running depends on which version of software is in the unit before it is updated.  This was changed some time back so that it is now mandatory to install the SD card after the unit is up and running if it has newer software on it.  I do not remember which software version changed this.
« Reply #6 on: May 16, 2013, 05:27:24 PM »
I must have mis-read the other post.  Thought someone had reported that their unit went into La La land when inserting the card before power up......guess the software just won't let you do that now.
Offline BillM
« Reply #7 on: May 17, 2013, 01:00:23 PM »
Sounds like the later revisions of firmware have the 'update' check after the system boots completely..   From a technical standpoint, this is the proper way to do things..
« Reply #8 on: May 17, 2013, 01:53:24 PM »
I agree.
Last post October 17, 2009, 06:24:50 AM
by capttim
Last post March 21, 2010, 09:43:28 PM
by FWP
Last post May 07, 2010, 03:51:28 PM
Last post March 30, 2011, 10:00:23 PM
by dw
Last post June 08, 2011, 04:28:43 AM
by T.G
Last post August 06, 2011, 12:07:41 PM
by hoselrocket
Last post March 10, 2012, 09:49:36 PM
by Moose1am
Last post July 03, 2012, 02:02:12 PM
