Author Topic: humminbird drpepth pre-made ethernet cable new  (Read 18409 times)
Offline fixitrod
« on: May 12, 2013, 01:39:31 AM »
I have a pre-made Ethernet cable used for Humminbid such as the 1197si and the 1198si. This cable was built by a very experienced network engineer. It is used in my case to get the full data into Dr. Depth live while scanning. I'm including a new 14ft cable with it. With this design you can use any standard cat5 or cat6.
Asking $55 shipped to the intra United States..
I'll try again with pic... hmmm!
« Last Edit: May 27, 2013, 04:09:55 PM by fixitrod »
Offline Walter
  • Scuba Diver
    • Preservation of cultural heritage
  • Unit(s): Eholote Humminbird Helix 9 CHIRP MEGA SI
Re: humminbird drpepth pre-made ethernet cable new
« Reply #1 on: May 17, 2013, 01:51:48 AM »
0 kB. Please re-upload file.
Diving club Daivings
« Reply #2 on: May 17, 2013, 02:07:40 PM »
Yeah, picture doesn't work.....If I ever get time, I would like to use this setup.
Offline fixitrod
« Reply #3 on: May 27, 2013, 04:08:55 PM »
OK, I think pictures are working now. If not, please let me know. Thanks for telling me!!
Offline Oceanscience
  • Z-Boat
    • The Oceanscience Group
« Reply #4 on: July 24, 2013, 04:50:39 PM »
Where can I purchase these cables?
Offline fixitrod
« Reply #5 on: July 24, 2013, 10:37:08 PM »
From me ;) this is still for sale. I bought a double ended cable for $45 on ebay, cut it, bought a patch cable, jack, terminated the jack on the cut humminbird, etc... But, you could make one too :)
  • Z-Boat
« Reply #6 on: July 24, 2013, 11:07:11 PM »
Since Dr Depth has been acquired, I can't find the wiring diagram/pinout to an RJ45 connector. Might you happen to have a schematic?
Offline fixitrod
« Reply #7 on: July 25, 2013, 07:05:58 AM »
Look up 568b standard. Im a network engineer I use this everyday :)
pin 1-8 (w is white)
w/orange
Orange
W/green
Blue
w/ blue
Green
W/brown
Brown
Offline diver651
  • Unit(s): 1197, 1198
  • Software: 6.47
  • Accessories: Interlink, Aux Speed/Temp,
« Reply #8 on: July 25, 2013, 12:46:59 PM »
Oceanscience,
I posted a reply to your request in another thread, but just in case somebody else does not see that I will answer here as well. Take a look at this thread that identifies the wires for connection between the Humminbird plug and a standard RJ45  end. It is the information I used making my fist cables and all of mine have worked well.
http://forums.sideimagingsoft.com/index.php?topic=2896.0
My first cables were produced by cutting a Humminbird cable and adding the RJ45 end, but I have made cables from scratch once I found a source for the M12 round plug like the Humminbird foks are using.
  • Z-Boat
« Reply #9 on: July 26, 2013, 01:44:57 PM »
Hey thanks guys! I wasn't sure if it was a special or standard configuration for RJ45. This will be very helpful.
- Oceanscience
PS Check out the video below! We will hope to implement on of the Humminbird SI units in the same was as the dual frequency echo sounder in the video.
Oceanscience Z Boat 1800 with CEESCOPE Dual Frequency 33/200kHz Echosounder Remote Sonar Boat
Offline diver651
  • Software: 6.47
« Reply #10 on: July 26, 2013, 02:03:27 PM »
Oceanscience,
The application should be pretty easy if your remote vessel is large enough to handle the battery and Humminbird unit.
I am already using the ethernet capability and wireless router to link to my laptop running Dr. Depth for real time image. I had been looking into putting the unit on a very small boat or  one of those inflatable twin pontoon fishing floats for easy deployment and simply pulling it across an area in a grid manner to build the complete image of the bottom.
Last post March 22, 2011, 05:34:04 PM
Last post March 13, 2013, 08:51:49 PM
by freezerfiller
Last post April 20, 2014, 09:25:49 PM
by knorstu
Last post March 06, 2014, 01:25:57 AM
Last post April 09, 2014, 06:30:55 AM
by bobcoy
Last post July 17, 2014, 10:41:29 AM
by ricqik
Last post December 06, 2018, 08:58:13 PM
by Fresnoron
Last post October 29, 2021, 08:47:11 PM
