Author Topic: Using two 898's for temporaty searching  (Read 14732 times)
Offline Highrubicon
  • wish I was fishing
  • Unit(s): Dual 898si
  • Accessories: autochart pro
« on: April 05, 2013, 08:30:44 AM »
I've got an 898 up front on my trition on a ram mount and one beside my dash. If i get the interlink and an extra 2 inch ball and power cord, can i hook the interlink to the rear gps antenna and hook the other 898 up to it behind the dash mounted 898 so i can run one on maps and other on side imaging and mark points while having full screen map. Then unhook it and move it back to the front, but i want it to use its on gps antenna on the front.
When in doubt, map it out!
Re: Using two 898's for temporaty searching
« Reply #1 on: April 05, 2013, 08:37:30 AM »
Yes you can but it would be far cheaper to use an Ethernet connection cable and it would work better as well.
Last post May 21, 2009, 04:10:56 PM
Last post February 22, 2010, 03:44:36 AM
by pebe
Last post September 20, 2010, 10:53:00 PM
by maachuu
Last post October 10, 2014, 09:08:50 AM
Last post August 27, 2012, 12:31:39 PM
by Rob Wood
Last post June 27, 2019, 04:10:25 AM
by Ronny
Last post June 29, 2019, 12:07:42 AM
