Author Topic: RF Interefence  (Read 3462 times)
Offline bobxxx
  • Unit(s): hb798cihd,hb helix9 si di mega,helix7 si
  • Software: 6.61,1.160,1.84
  • Accessories: AS GPS HS
RF Interefence
« on: April 02, 2013, 12:12:31 PM »
when using 2 hb units.,I read an article that said to reduce interference,when using dual beam transducers,is to put 1 unit on 200 khz and the second unit on 83 kHz.My question is ,on the  HB 798 ,when you turn off the 83 or 200.,does the HB turn off the transmitter or receiver.ie: does the unit keep transmitting and just not process the the returns?
Offline wolfs4evr
Re: RF Interefence
« Reply #1 on: April 02, 2013, 02:15:54 PM »
You can't turn off 200khz.  That freq is used for your depth.  83khz is the only frequency that can be turned on/off.
Less than ~20 feet or so I can run both of my units w/o interference.  In water greater than 20 I get vertical lines on my screen.  Fairy easy to tell it is cross talk, etc.  You can fish through it.  If it bothers me too much and I am the only one in the boat I turn my console sonar off.  If someone else is fishing in the back of the boat I use the Ethernet settings so that both units use the same transducer thus eliminating cross talk.
Offline bobxxx
Re: RF Interefence
« Reply #2 on: April 02, 2013, 02:33:58 PM »
Thanks for your time,
Bob
Re: RF Interefence
« Reply #3 on: April 02, 2013, 04:23:59 PM »
You can also try turning on and up the Noise Filter menu on the unit that is showing the sonar interference.
