Author Topic: GPS not working on new 1198c install  (Read 14427 times)
Offline DDH1962
  • Unit(s): 1198c
« on: March 23, 2013, 09:28:35 AM »
I had this unit installed at boat dealer on new boat and everything seems to work except GPS. It shows the following
Fix type- no fix
EST POS Error-2669sm
will the new download provided by HB fix this or is there another issue.
The unit was purchased new in Jan 13.
Thanks for any help.
Re: GPS not working on new 1198c install
« Reply #1 on: March 29, 2013, 01:37:18 PM »
Is this with the GR50 or GRP GPS Receiver (look on the top of the GPS Receiver)?
What software version is your 1198c Si unit running?
Do you know of someone else that has a Humminbird unit with an external GPS that would let you test your unit on their GPS Receiver?
Offline Sam K
  • Unit(s): 787c2i,1198c SI
  • Accessories: Interlink
« Reply #2 on: March 31, 2013, 01:26:03 PM »
I am having the same issue on my new unit. Completely uninstalled all wires and cables then reinstalled to be sure connections were good. Tried running power directly from battery to eliminate a possible cause even though I was showing 12.1 volts on the unit. Diagnostic still shows gps connected with no fix and the 2669 error. All other functions of the unit work. GPS receiver is GR50.
« Reply #3 on: April 01, 2013, 02:22:15 PM »
Make sure that you guys are testing these outside where the GPS Receiver has a clear view of the satellites.
Is either of your units showing any satellites as being tracked?  A Screen Snapshot of the GPS Diagnostic View could help with this.
Again, see if you can find someone else who has a Humminbird unit with an external GPS Receiver that will let you test your unit on their boat and while you are at it; their unit on your boat.
Offline Sam K
« Reply #4 on: April 02, 2013, 01:20:51 AM »
I thought maybe I wasn't getting a clear view of the satellites while testing the unit in my driveway. Spent Friday and Saturday on two different lakes hoping it would make a difference but no luck. The unit is showing that it's tracking satellites on the diagnostic screen but no gps fix. I've got a buddy with a  900 series. We're going to try and get together this weekend and test our units on each others boats. I'll post the results. Thanks.
« Reply #5 on: April 02, 2013, 07:07:52 AM »
You could also check under the NAV menu, for
the GPS receiver override.
Set it to Auto.
Offline Sam K
« Reply #6 on: April 02, 2013, 01:11:43 PM »
I tried both the auto and external setting but neither one made a difference.
« Reply #7 on: April 02, 2013, 04:29:08 PM »
Please get screen snapshots of what the GPS Diagnostic View looks like on each unit when you test them.
Offline Sam K
« Reply #8 on: April 08, 2013, 10:00:17 AM »
Tested my unit on my buddy's boat on Sunday, and the gps works fine while I'm connected to his boat. Still nothing on my boat with either one of our head units. I think my gps receiver is bad. I have pictures, but I'm having problems posting them on here.
« Reply #9 on: April 08, 2013, 11:37:18 AM »
Sam K,
I would not worry about the pictures as it sounds like you have identified that your problem is the GPS Receiver as your unit worked on your buddy’s boat (GPS Receiver).  Call the Humminbird Customer resource folks to set up getting the GPS Receiver fixed (most likely will just get replaced).
Offline Sam K
« Reply #10 on: April 08, 2013, 01:04:32 PM »
Greg, thanks for your help. I will call Humminbird this week.
Offline DDH1962
  • Unit(s): 1198c
« Reply #11 on: April 09, 2013, 09:46:24 PM »
I have tried everything except another boat hook up.(dont know anyone around near me with humminbird set up) i called humminbird and they said to send the unit in. I am going to call again and ask if they still want me to send or just replace the GPS puck. Thanks for the information. Will let you know the result.
Offline Sam K
« Reply #12 on: April 17, 2013, 01:41:06 PM »
New gps puck arrived from Humminbird today. Hooked it up and the gps works like it's supposed to. Definitely had a bad gps puck to begin with. All is well now.
Last post June 05, 2011, 12:58:14 PM
by edwardpic
Last post October 19, 2011, 10:12:11 AM
Last post March 23, 2012, 03:23:06 PM
by rheykoop
Last post May 01, 2012, 04:38:28 PM
by Chet2142
Last post May 02, 2012, 09:53:53 AM
Last post August 06, 2012, 03:42:11 PM
Last post January 10, 2013, 12:56:19 PM
by Zildjian
Last post April 07, 2013, 10:16:15 PM
by Scrutch
