Author Topic: My First Dumb Operations Question 998c  (Read 9951 times)
Offline MTBob
  • MTBob
  • Unit(s): HB 998c
« on: March 23, 2013, 01:30:47 AM »
OK, I got the 998c SI unit installed, transducers mounted, cables run and screen "lit up".  The water in Montana is still mostly solid so there's no way I can give the outfit a run.  So, I'd like to make sure that the transducers & GPS are connected properly and the system is working as it should.  Is there a way to tell if the unit is functioning properly while it's sitting in my shop?  Is there a system test function?
Bob
Re: My First Dumb Operations Question 998c
« Reply #1 on: March 23, 2013, 04:45:32 PM »
Yes, there is a diagnostic screen.
I haven't used it in a while, but I think you just have to enable it to be visible and you will see it when cycling thru the views.  I think you have to be in advanced mode first.
Offline MTBob
  • MTBob
  • Unit(s): HB 998c
« Reply #2 on: March 23, 2013, 05:15:26 PM »
Thanks Bob, I'll check it out.
Bob
« Reply #3 on: March 29, 2013, 01:50:18 PM »
There is really no way to tell if your system is working correctly until the water thaws.
Last post February 15, 2010, 09:32:13 PM
Last post September 11, 2010, 10:10:15 AM
Last post January 27, 2012, 06:30:08 PM
by sonar112
Last post April 04, 2012, 02:12:55 PM
Last post October 13, 2012, 09:39:03 AM
by Rickard
Last post January 03, 2013, 06:23:43 PM
Last post April 16, 2013, 02:09:35 PM
Last post July 25, 2021, 08:32:22 PM
