Author Topic: Issues with 6.60 Update  (Read 7131 times)
Offline dturnersr
  • Unit(s): Twini-998c si
« on: March 22, 2013, 02:07:54 PM »
Just FYI recently downloaded the new update 6.60 for two units.  A few issues:
1.  Even after downloading the update on SD cards and verifying update is present several units did not want to up load until after several attempts using the prescribed methond.
2.  After down loading the 360 simulation images display error codes for images unless screen is toggled.
3.  Unit shut down self initiated when toggling through screen function in simulation mode.
4.  The video out function is disabled.  I verified this on several different units and with other friends.   I was able to restore the function by reloading 6.180; however, as I give classes and seminars it's a pain to have to swap back and forth to use the 360 screens.  I understand through several contacts a new update is pending to address these issues.
Have a great day.
David
Re: Issues with 6.60 Update
« Reply #1 on: March 22, 2013, 03:43:01 PM »
6.610 software is out for most, if not all of the units that received the 6.600 software, but I don’t remember reading that it took care of any video output problems.
Offline dturnersr
« Reply #2 on: March 22, 2013, 04:52:52 PM »
The newest update available for 998's is the 6.60.  Greg what does the 6.10 resolve?  I am expecting arrival of my new 1198C Si any day.  I am hoping it has newest updates already, but expecting it will not.
« Reply #3 on: March 29, 2013, 01:35:23 PM »
Check you r account again.  I did and mine shows the 6.610 software:
998c SI(Version 6.610)
Release Date: 03/15/2013
Description:
v6.610 includes changes to POS Script Updates and includes general performance and stability updates plus everything included in v6.600
• Added enhancements for 2D/DI/SI sonar scroll rate on the 798ci HD SI.
• Fixed an issue where SI data was scrolling at twice the intended rate.
• Fixed an issue where 2D/DI data was not in sync on the 798ci HD SI.
• Fixed an issue where 2D/DI data was not in sync if 83/200 kHz mode was enabled.
• Fixed an issue where DI Zoom was not in sync.
• Fixed SI Sensitivity issues on the 898c SI, 998c SI, 1197c SI, 1198c SI.
• Fixed an issue where Demonstration Mode OFF would not force normal mode and a connected transducer state.
• Fixed an issue where rapidly forcing the unit into Simulator Mode could cause the unit to restart.
• Fixed an issue where Ethernet sonar subscriptions would eventually drop off if the Control Head was booted with Sonar turned Off
• Fixed an issue where Ethernet sonar subscriptions would eventually drop off if Sonar was turned Off and then back On within 60 seconds without a reboot.
• Fixed an Ethernet issue where the Heading Line ON/OFF setting would not be saved between restarts while subscribed to a remote AS GPS + HS.
• Removed Universal Sonar II transducer selection option, now users should select dual beam as their selection.
• LakeMaster map coding was updated to work with i-PilotLINK
• Tweaks were made to radar functionality to fix a memory leak
• Fixed a bug that caused some models to sometimes skip a view when cycling through views.
• Locked NMEA output at 4800 baud when enabled
• Added 360 Imaging operation menus and capabilities
• Added iPilotLINK operation menus and capabilities
by fishinphil
Last post January 11, 2013, 02:09:23 PM
Last post July 29, 2013, 01:46:32 PM
Last post September 09, 2013, 04:07:10 AM
by prowler650
Last post November 17, 2014, 10:13:06 AM
Last post April 04, 2015, 05:03:25 PM
Last post April 14, 2016, 09:35:48 PM
by CamoHunter
Last post August 05, 2018, 08:50:43 PM
