Author Topic: Lake master load  (Read 10844 times)
Offline Btrent
  • Unit(s): 898csi
Lake master load
« on: March 20, 2013, 12:08:03 PM »
Trying to load lakemaster chip at home om 898 c si got the cable any help would be great thanks
Re: Lake master load
« Reply #1 on: March 20, 2013, 12:38:39 PM »
Cable for what?
No cable is needed to install the LakeMaster mapping card into your Humminbird unit.
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
« Reply #2 on: March 20, 2013, 01:38:22 PM »
Yeah, just open the little door on the lower right side of your 898 and push the lakemaster card in one of those slots.
Offline Btrent
  • Unit(s): 898csi
« Reply #3 on: March 20, 2013, 05:12:31 PM »
I did that can,t get the map to come up
« Reply #4 on: March 20, 2013, 05:54:06 PM »
Did you power off the unit and then put the card in and then power on. Sometimes these units do not recognize the card after the unit is powered on...dont know if this is your particular case but try it anyway.
Also does the card read in your computer. It (the pc) should give you card info: filename, size type, etc.
If the computer does not read then the card may be bad.
Offline Btrent
  • Unit(s): 898csi
« Reply #5 on: March 20, 2013, 06:54:52 PM »
Chuck I will try it in my pc thanks i loaded it both ways 1st time unit was off put the card in and fired it up got  all the maps to pick from just could not get a look at the maps at all should be able to look at them though just not sure if if the maps would show or not thanks
Last post June 01, 2010, 03:49:12 PM
by scubatelco
Last post February 06, 2011, 08:22:17 AM
by stillbear
Last post April 13, 2011, 07:31:19 PM
by Jasta
Last post December 22, 2011, 02:21:06 PM
by LocDown
Last post March 11, 2015, 10:22:25 AM
by SkeeterMatt
Last post March 06, 2015, 10:46:51 PM
by rabbit1953
Last post March 10, 2015, 03:53:23 PM
Last post October 29, 2015, 09:18:05 PM
by tschultz
