Author Topic: No power in my 898 c si  (Read 20837 times)
Offline fishi
  • Spinning is the King!
  • Unit(s): 898 c si
« on: March 18, 2013, 06:51:18 AM »
Hy everybody,
my name is Adrian and i am from Romania(sorry for my english) .I have a big problem with my 898 c si unit.Yesterday i start the unit and after 3 minute he death ,no power, no nothing.I check the batery but was ok,i check the power cable on the another unit and was ok.So im in the deep trouble whith that .Can somebody to tell me if exist inside the unit a fuse(electronical fuse) or anything else ?Maybe(if existe) changing this fuse my unit gona work again!?
Thank's a lot!
Adrian
ps.sorry for my english!! :-[
Live every day as if it would be the last!
Re: No power in my 898 c si
« Reply #1 on: March 19, 2013, 10:37:02 AM »
No fuse inside the unit Adrian.
This other unit that you tried; what model was it?
If it does not use as much power as the 898 unit it may not be a good test of the wiring and battery.  Try connecting your 898 unit to another battery to test it.
Offline fishi
  • Unit(s): 898 c si
« Reply #2 on: March 19, 2013, 12:35:50 PM »
same unit
i try with another batery but nothing,today i try to open my unit and check the wire inside
I keep in touch!
Adrian
Offline fishi
  • Unit(s): 898 c si
« Reply #3 on: March 19, 2013, 03:31:12 PM »
i opened the unit and there was nothing to fix inside,every piece look  in a good condition,i think is necesary to send my unit in US,l don't know anything to do.....is extremely expensive to me this ,,move''
Offline navionic
« Reply #4 on: March 20, 2013, 04:15:41 PM »
Hy everybody,
Thank's a lot!
Adrian
The problem at the connection cable to the unit. Poor contact. You can fix yourself. Need a thin and sharp object.
« Last Edit: March 20, 2013, 04:16:45 PM by navionic »
Offline fishi
  • Unit(s): 898 c si
« Reply #5 on: March 21, 2013, 03:17:33 AM »
I try today whith a needle,thanks a lot.
Offline fishi
  • Unit(s): 898 c si
« Reply #6 on: March 21, 2013, 02:35:34 PM »
i try-it,nothing happened :'(
Offline Birdhunterden
  • Unit(s): 898c si
  • Software: ?
« Reply #7 on: March 22, 2013, 10:47:32 PM »
Check your ground wire it may be loose
« Reply #8 on: March 23, 2013, 02:51:06 PM »
Use a small screwdriver to slightly push the pins outward to help with connection.  You can tell if they are loose when you pull on it and it wiggles off easily.
Be carefull when doing this, you just need to push the pins out slightly to help.
Good luck,
Offline fishi
  • Unit(s): 898 c si
« Reply #9 on: March 25, 2013, 03:19:43 AM »
I try't but still nothing.
« Reply #10 on: March 25, 2013, 07:55:29 AM »
Is there a customer service center in your area?
Is the unit under warranty?
Can you return it to where you bought it for service?
Offline fishi
  • Unit(s): 898 c si
« Reply #11 on: March 26, 2013, 03:55:28 AM »
In Europe nobody want to fix\repair my unit,why??? because i buy the unit from US!!!
When my unit leaves US, i loose the waranty(my unit is in ,,Humminbird Select'' clasification)
I try to send my unit in US for repair,now is the only option.
Offline navionic
« Reply #12 on: March 26, 2013, 04:22:47 AM »
Humminbird Select program only for the U.S. and Canada.
If  do not help to correct contacts, only in U.S.  Alas, in Europe there is no service center and does not seem to be never. :(
Offline Rüdiger
« Reply #13 on: March 26, 2013, 04:46:50 AM »
Outside the U.S. can no hardware errors are fixed. :( The "service center" in Europe to send units with hardware problems for manufacturers in the U.S. and the oft with gigantic delay. The repair of my 898er lasted over 5 months. >:(
Therefore send equipment itself, which goes much faster.
mvh
Rüdiger
Finding is better than losing
Offline navionic
« Reply #14 on: March 26, 2013, 04:57:06 AM »
 :o
Humminbird  is not interested sale of its model  in Europe. So sorry.
fishi
A lot a lot of patience. Good luck!
« Last Edit: March 26, 2013, 05:00:18 AM by navionic »
Offline fishi
  • Unit(s): 898 c si
« Reply #15 on: March 27, 2013, 03:32:35 AM »
I understand ,i don't want anything for free,i want to repair my unit and i want to use at fishing,that's all.I dont want warranty,i don't want Humminbird Select....But i dont think is normal,in my opinion.I pay for this unit my  salary on 4 month ago....and i use this unit 1 year (purchase in february 2012) whitout the winter(5 month in Romania,a lot of ice!)
Offline navionic
« Reply #16 on: March 27, 2013, 03:38:21 AM »
Unit is not under warranty. Here are all described in detail and the cost of repairs. Good luck!
http://www.humminbird.com/Faq.aspx?TaxonomyId=95A1764
Offline fishi
  • Unit(s): 898 c si
« Reply #17 on: March 27, 2013, 03:55:49 AM »
Thank you so much!
You have here what i do in Romania for fishing.
http://spinningteambv.wordpress.com/
My name is Cenusa Adrian(that's my face with a walleye ) http://spinningteambv.files.wordpress.com/2010/02/adi1.jpg
and here some fish
http://www.rapitori.ro/forum/gallery/album.php?album_id=389
Offline Rüdiger
« Reply #18 on: March 27, 2013, 04:01:30 AM »
Hi Fishi
My unit was repaired free of charge after the warranty :). Do not open your unit self and send it directly to the manufacturer!!
Good luck
Rüdiger
Offline navionic
« Reply #19 on: March 27, 2013, 04:33:37 AM »
Very lucky :)
Offline fishi
  • Unit(s): 898 c si
« Reply #20 on: March 27, 2013, 06:59:45 AM »
Wow,good for you but i dont think i have your luck.
Offline fishi
  • Unit(s): 898 c si
« Reply #21 on: April 25, 2013, 03:38:06 PM »
I fix my problem.............in US.My unit work now.Thank's everybody!
Offline navionic
« Reply #22 on: April 25, 2013, 03:52:56 PM »
Good news.
by depark1
Last post November 27, 2014, 08:07:13 AM
Last post December 15, 2014, 03:42:39 PM
by SkeeterMatt
Last post July 05, 2015, 09:12:04 AM
by N9Phil
