Author Topic: Sunken Jon Boat  (Read 16365 times)
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
Sunken Jon Boat
« on: March 16, 2013, 09:40:33 PM »
I caught this a hundred yards from the boat ramp. And it looks like a good image of a sunken jon boat.  You can see the ribs in the hull.  I thought this was from some duck hunters that submerged in January, but I don't see a motor, so I doubt it is the same.  Also appears to be a school of baitfish off the bow... Thoughts?
« Last Edit: March 16, 2013, 09:42:13 PM by freezerfiller »
Re: Sunken Jon Boat
« Reply #1 on: March 16, 2013, 09:59:41 PM »
Great pict!  I dont see a motor either.  Now you just need to dive down, hook it up and pull it to the bank!
  • Unit(s): 998c SI
  • Software: ??
Re: Sunken Jon Boat
« Reply #2 on: March 16, 2013, 10:53:01 PM »
Maybe when that water temp climbs 20 degrees, I'd consider it... ;D
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Sunken Jon Boat
« Reply #3 on: March 16, 2013, 11:21:48 PM »
What I think is the bow of your boat is casting a pretty large shadow for traveling almost
directly over it. Maybe the motor fell off and is underneath it.
Offline short grub
  • Unit(s): 1198 SI combo, 1159 DI combo
  • Software: latest
  • Accessories: terrova 80lb w/I*lLink 360transmt
Re: Sunken Jon Boat
« Reply #4 on: March 17, 2013, 07:09:06 AM »
FF it looks like you have some kind of blockage on the left side of your SI beam
oh cool pic
and yes wait for the water to warm a bit before you go dive that wreck
good job sir
  • Unit(s): 998c SI
  • Software: ??
Re: Sunken Jon Boat
« Reply #5 on: March 17, 2013, 09:10:28 AM »
My apologies, I had the bow and stern confused.  baitfish off the stern.   Yes, there is some blockage on the left, which I am attibuting to the trim tab.  I'd rather live with the interference than without the trim tab.  So far I havent had much of an issue seeing what I need to over there.
Offline 234rick
Re: Sunken Jon Boat
« Reply #6 on: March 17, 2013, 10:38:26 AM »
So that Jon boat is 30 feet long & 12 feet wide ?????????
Offline Rickard
Re: Sunken Jon Boat
« Reply #7 on: March 17, 2013, 11:22:49 AM »
With correction the boat seems to be about 36 feet long - must be something else than a Jon boat.  :-\
  • Unit(s): 998c SI
  • Software: ??
Re: Sunken Jon Boat
« Reply #8 on: March 17, 2013, 04:35:35 PM »
Hmm.  If I had known it was that big, I would have dropped a hook.  Those might have been some nice crappie.  Sure looked like a jon boat... I was in Alabama, so there's really no way to be sure ;D  So to understand, you just compared the length of the object vs, the 100ft to determine the length of the Roll Tidetanic?
Offline Rickard
Re: Sunken Jon Boat
« Reply #9 on: March 17, 2013, 05:17:32 PM »
Yes, just relating the length of the object to view width gives a rough estimate of object size. To arrive at a more precise estimate the Pythagorean theorem is used. This is called "slant range correction". The corrected distances/lengths are always longer than before correction.
Re: Sunken Jon Boat
« Reply #10 on: March 17, 2013, 06:15:19 PM »
I have to agree.  I didn't pay attention to the depth and range when I first looked at it.  It is pretty big.
What had me thinking it was something unusual was the shadow.  Do you notice the two shadows on each side of the stern?  They are very pronounced and are protruding from the sides.
If you get a recording of the target, you can play it back on one of the viewers and possibly bring out some more detail.
Could be a small barge of some sort!
  • Unit(s): 998c SI
  • Software: ??
Re: Sunken Jon Boat
« Reply #11 on: March 18, 2013, 12:10:52 PM »
I did notice those shadows..  I will get back out to that spot later this spring, and see what else I can learn about it. It does look boatish though.  Might be an old dock building barge or something.
Last post June 18, 2009, 10:05:20 AM
Last post April 11, 2012, 09:01:38 PM
by Roddy
Last post March 07, 2013, 06:57:05 AM
by Walter
Last post November 08, 2012, 12:08:43 PM
by Bobcat316
Last post June 21, 2013, 06:50:18 AM
by promapper
Last post November 20, 2013, 01:09:00 AM
by snapperbasher
Last post April 30, 2014, 05:56:21 AM
by Saltykayak
Last post July 25, 2021, 02:38:37 AM
by Rüdiger
