Author Topic: Side Beam View using SI transducer  (Read 11253 times)
Offline didier74
  • Unit(s): 1197 cx SI/1198 cx SI
  • Software: 6.310/6.490
  • Accessories: Ethernet switch
« on: March 09, 2013, 04:40:03 AM »
Is it possible to have Side beam View
Using Side Imaging transducer ?
The two transducers working at 455 KHz, does having one Side Imaging transducer connected with following settings is it fine ?
  1-transducer select:quadrabeam
  2-side view frequency:455 KHz
Thanks for help
Sorry English not my first language...
Offline Rickard
Re: Side Beam View using SI transducer
« Reply #1 on: March 09, 2013, 04:36:22 PM »
Hi,
Yes, as far as I know that's possible. But I can't see the point in doing it since most things will be less good and efficiently displayed than with the standard transducer setting. The QuadraBeam transducer is a simpler transducer than the sideimaging transducers are. The only thing that might be better is the ability to indicate fish in the "sidebeams" with the QuadraBeam transducer. The algorithm for this probably doesn't work with a sideimaging transducer because of the very much narrower beam.
Rickard
« Last Edit: March 09, 2013, 06:43:34 PM by Rickard »
Offline didier74
« Reply #2 on: March 11, 2013, 01:54:04 AM »
Thanks for your reply Rickard
Yes my idea was to see fish in the "sidebeams"
But if you think, doesn't work good, not going to waste my time with
by Sonshine Fishing
Last post November 08, 2010, 09:46:01 AM
Last post September 26, 2011, 11:07:04 AM
Last post December 05, 2011, 12:20:17 PM
Last post February 10, 2012, 09:24:52 AM
Last post September 20, 2014, 07:11:13 PM
Last post February 01, 2017, 10:03:47 PM
by Coach
Last post January 02, 2020, 09:16:25 AM
by Arkee
