Author Topic: missing .son files  (Read 17793 times)
Offline kevinr1963
  • Unit(s): 898c hd si
missing .son files
« on: February 12, 2013, 08:01:16 PM »
when loading my recordings using either humviewer or hbsi file converter it  always fails. saying one or more files missing. can anyone help
Re: missing .son files
« Reply #1 on: February 13, 2013, 12:57:43 AM »
Its important that you transfer all the files over from the sd card correctly.  You have to copy the entire RECORD folder and keep all the files in their correct place.  The corresponding .DAT file along with its R000* folder should be transfered if you if you are trying to transfer them individually.  See the text below to understand the structure.
Quote
When the recording is started, the unit creates a R0001.DAT file in the RECORD folder on the SD Card. (The file name is incremental, so the next recording file name would be R0002, R0003, and so on.)
A folder named R000*  is created in the RECORD folder and this is where the actual recording files are stored.  Inside each R000* folder you will have at least 6 files (sometimes 8 files) .  The files are:
B000.IDX     - B000 is used for the 83khz or 50khz 2d sonar depending on the transducer being used.
B000.SON
B001.IDX     - B001 is the 200khz 2d sonar
B001.SON
B002.IDX     - B002 is the Port Side (left) SI Sonar and the frequency can be 262khz/455khz/800khz
B002.SON
B003.IDX     - B003 is the Starboard Side (right) SI Sonar and the frequency can be 262khz/455khz/800khz
B003.SON
You will always have B001, B002, and B003.  B000 will only be recorded if the user has the 83 or 50khz transducer turned on.
Offline kevinr1963
« Reply #2 on: February 14, 2013, 07:14:56 PM »
i opened my record file it had B000 B001 B002 B003 both .IDX and >SON. i was wondering if i was using the proper software. i have a vista 32 bit. i could not have a humviewer for a 32 bit so i downloaded the HBSI for vista. is this the right program or can you please send me a link. thank you
Offline kevinr1963
« Reply #3 on: February 17, 2013, 01:53:34 PM »
i tried loading a recording again after reloading hbsi. this time i get error incorrect check bit 35 at position 35. i went into hummingbird PC and re formated by SD card but with no change. i am using a PNY Premium 8 GB card this week i will get a sandisk extreme 3 card and try it again. i will figure this out but any help is welcomed. smile
« Reply #4 on: February 18, 2013, 05:09:11 PM »
kevin,
What version software do you have loaded on your unit.  I have been just getting back into things here and have not checked out some of the latest updates.  If they have made some software changes that have changed the HB format or structure, that would give you the Checkbit 35 error.
Offline kevinr1963
« Reply #5 on: February 18, 2013, 07:23:18 PM »
i am running the 6.6 update for the 898. on the water the main issue i have seen is the depth will drop out and come back in. if you want me to try an older version of the software. you would have to tell me where to get it. i am new and learning but i have no ideal where to get that from. thank you Kevin
Last post June 20, 2013, 09:01:10 AM
by Blinky_Hunter
Last post July 30, 2013, 11:02:23 AM
by bass student
Last post July 08, 2014, 03:55:45 PM
Last post April 30, 2016, 04:24:38 PM
by mike fish
Last post July 21, 2015, 12:03:32 AM
by Spd 135
Last post April 12, 2019, 06:37:22 AM
by danlaboucane
Last post May 12, 2024, 11:42:33 AM
by dpcook
Last post November 17, 2023, 01:25:24 AM
by navionic
