Author Topic: Powering up 898 on shore  (Read 10409 times)
Offline busterboy2238
  • Unit(s): 898si
  • Software: latest
« on: February 11, 2013, 02:22:46 PM »
I want to power up the 898 in the comfort of my home. Is there an off the shelf connector that I can solder onto my power adapter cable? or do I need to purchase a stand alone power cable from Humminbird, then modify it to my power adapter?
What is the price of the Humminbird cable?
Thanks.
Offline Rüdiger
Re: Powering up 898 on shore
« Reply #1 on: February 12, 2013, 03:44:05 AM »
Hi Buster
With some skill, you can save yourself an expensive original cable. Put the wire ends directly into the two openings on the back of your device and fix this example then with toothpicks. added a bit rustic, but cheap. Important note polarity!
mvh
Rüdiger
Finding is better than losing
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
« Reply #2 on: February 12, 2013, 11:19:55 AM »
I did the plug the wires in the back for one night, but I deemed it generally unsafe for my unit and my power supply.  The best deal I found on the cable was from Amazon.com,   I used an old laptop power supply and a 2a fuse.   Maybe one day someone will start making these things to power some FCC approved device with the same power requirements... ;)
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Offline tgordon
  • Unit(s): 898c HD SI Combo, 788ci HD DI
« Reply #4 on: March 06, 2013, 10:10:42 AM »
I call this "The Nest." I used an old Wide Eye base for my 788 HD DI. I bought a cord for my 898 HD SI and a new mount from Amazon. I use a 12 volt converter I've had for many years.  I put a two amp inline fuse to be on the safe side and mounted it all on a 1X12 board 30 inches long.
TG
Terry Gordon
Salvisa, KY
Offline tgordon
« Reply #5 on: March 06, 2013, 10:15:58 AM »
Sorry the pix are upside down.
TG
Terry Gordon
Salvisa, KY
  • Unit(s): 898si
  • Software: latest
« Reply #6 on: March 06, 2013, 01:14:51 PM »
Thanks so much!
Last post March 18, 2012, 10:41:31 AM
by Jason
Last post May 29, 2012, 11:50:59 AM
Last post May 06, 2013, 05:32:15 PM
Last post September 29, 2013, 12:29:19 AM
by cjbfisher
Last post June 16, 2014, 05:43:37 PM
by MadTownGator
Last post November 12, 2015, 08:22:00 PM
Last post December 19, 2016, 01:52:21 PM
by Baker11
Last post September 12, 2021, 11:11:10 AM
by kentman
