Author Topic: 998c si switching itself off  (Read 8695 times)
Offline stoporilshoot
  • Unit(s): 998c SI
« on: February 10, 2013, 10:25:37 PM »
Hello....I updated the set a while ago (forget the version but it has the contour mode update)
Now when I scroll through the views when the set is running it turns itself off...this has happened a few times
Any ideas?
Cheers
Re: 998c si switching itself off
« Reply #1 on: February 12, 2013, 01:34:16 PM »
First, figure out what software version your unit is running.
Does this happen while the unit is on your boat or are you powering your unit up in the house?
Are you using any sort of mapping card or memory card in the unit when this happens?
  • Unit(s): 998c SI
« Reply #2 on: February 12, 2013, 03:33:29 PM »
Hello Greg,
It happens when I'm on the boat, I'm using a navionics gold chart card, I'm not recording/mapping any information when it happens. As I say it happens when I'm scrolling through the views.
  I'm presently away at work at the moment but will check which version I am running when I get home, I downloaded the update around May time last year, it had the countour mode fix/option to get rid of the water column if required
Cheers
« Reply #3 on: February 13, 2013, 08:45:45 AM »
There have been four software updates to the 998 units since then but I don’t know if any of them will help your unit or not.
See if this same thing happens without the Navionics card installed.
Offline Gattlin
« Reply #4 on: February 14, 2013, 10:44:59 AM »
 The 898 on the console was doing that. In the end what fixed it for me was wiring it straight to the cranking battery. I was losing voltage somehow at the fuse panel, a bad connection perhaps. Good luck :)
Just one last cast.
Last post August 10, 2009, 11:01:33 AM
Last post February 24, 2012, 01:19:27 PM
Last post June 05, 2012, 10:16:20 AM
by wolfs4evr
Last post September 04, 2012, 05:28:21 PM
by BCLII
Last post December 15, 2012, 12:10:23 PM
by Jim Jack
Last post May 20, 2013, 01:00:01 PM
Last post March 30, 2016, 01:23:29 PM
by jjbch
Last post May 08, 2018, 11:03:19 PM
