Author Topic: Sanpshot with Lakemaster chip  (Read 12282 times)
Offline LBloch
  • Unit(s): 998c SI, 958c
  • Software: 6.18
« on: February 10, 2013, 09:10:09 PM »
I've been struggling a bit with the snapshot feature on my 998c.  I understand how to turn on the snapshot function and how to get a snapshot of the screen.  However for some reason, my snapshots keep getting saved onto my Lakemaster chip, even when I have a blank sd card in the other slot of the card reader.  Is it not recommended to take snapshots with a Lakemaster chip in the unit?  What am I doing wrong? I really don't want to fill up my Lakemaster chips with snapshots.  Thanks
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Sanpshot with Lakemaster chip
« Reply #1 on: February 10, 2013, 09:22:25 PM »
lbloch
   I believe that snapshots are saved to the units memory and not to either card. LM or blank SD
   To get the snapshots to a card, you export them from the unit. Recordings go directly to the card.
Offline LBloch
  • Software: 6.18
« Reply #2 on: February 10, 2013, 09:35:30 PM »
Ok.  I guess I undertand that.  Can I practice doing that in the simulator mode?  Or does it have to be in normal mode?
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: February 10, 2013, 09:57:31 PM »
lock the map card to readonly and make sure the other card is NOT in lock mode.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #4 on: February 10, 2013, 10:09:30 PM »
lbloch
  I'm sorry. I mixed one of my responses ( since deleted) with another thread that I was following.
  LocDown has the answer your looking for.
Offline LBloch
  • Software: 6.18
« Reply #5 on: February 10, 2013, 10:13:39 PM »
No problem.. You had me confused though!  I think I figured it out. I hooked up a transducer and gps and ran it in normal mode.  I took some screen shots and it seemed to work.  One thing I noticed is the numbers of the snapshots doesn't reset to "0" after I delete the images from the unit.  Is that normal?
Offline LocDown
    • Fishing Videos
« Reply #6 on: February 10, 2013, 10:15:35 PM »
That is normal
Offline LBloch
  • Software: 6.18
« Reply #7 on: February 10, 2013, 10:19:18 PM »
Thanks LocDown.  Is that what the little sliding "lock" button is for on the sd cards?  I thought that if I had that little button in the lock position the maps on the sd card wouldn't load into my unit.  Learning a lot here tonight. Thanks again
Offline LocDown
    • Fishing Videos
« Reply #8 on: February 10, 2013, 10:20:40 PM »
Yes, that is the write protect lock. You don't want your expensive map card accidentally getting borked right? :)
Offline LBloch
  • Software: 6.18
« Reply #9 on: February 10, 2013, 10:24:19 PM »
Well I have a couple of wayPoints on one of my lakemaster chips.. luckily it didn't hurt it any.  That's the probably the most important thing I learned here tonight!
« Last Edit: February 10, 2013, 10:32:37 PM by lbloch »
Last post May 28, 2010, 09:35:53 PM
by BEE
Last post July 15, 2010, 04:25:49 PM
by raricker
Last post January 16, 2011, 04:43:27 PM
Last post November 21, 2013, 02:58:29 PM
by FuzzyGrub
Last post March 22, 2014, 02:25:56 PM
by ezfishn
Last post July 07, 2014, 01:22:14 PM
Last post March 03, 2015, 11:49:33 AM
by Have Rod, will travel
Last post September 07, 2015, 06:22:37 PM
by nicknight
