Author Topic: Hot tip for tablet owners  (Read 12001 times)
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
« on: February 05, 2013, 10:20:23 PM »
Have a tablet and don't want to take it out on the water for fear of getting it wet/salty/sandy?  I've been doing this for 2 years now, and I thought I'd share.  If you have a foodsaver or other similar food storage system, you can put your tablet in a bag, provided your system offers a smooth side, and seal it up.  You can't charge it, or plug anything into it, but if you just want to use your navionics app, or read a book on the boat/beach, this is the ticket.  The touch screen and buttons work like a charm.    I don't pull a full vacuum, just enough to lay the plastic smooth on the screen.  If you pull too much vacuum, your buttons may stick...
Offline strawdg
Re: Hot tip for tablet owners
« Reply #1 on: February 05, 2013, 11:22:15 PM »
And it will probably cook itself in that bag ..... >:D
Straw
  • Unit(s): 998c SI
  • Software: ??
« Reply #2 on: February 05, 2013, 11:34:30 PM »
Havent had an issue yet, and I've had it out on the boat and the beach several times, but I can't say I've left it in direct sun for an extended period.
« Last Edit: February 06, 2013, 07:20:48 AM by freezerfiller »
Offline short grub
  • Unit(s): 1198 SI combo, 1159 DI combo
  • Software: latest
  • Accessories: terrova 80lb w/I*lLink 360transmt
« Reply #3 on: February 06, 2013, 07:28:18 AM »
 cool trick sir
thank you
« Reply #4 on: February 06, 2013, 11:32:34 AM »
Have you tried using a freezer grade zip type food storage bag?
Which tablet you got?  I’m running a Samsung Galaxy 10.1
  • Unit(s): 998c SI
  • Software: ??
« Reply #5 on: February 06, 2013, 12:14:52 PM »
My daughter has the ASUS transformer, and I have the kindle fire HD.  It is likely going to become my wife's as It doesn't have a gps in it, but I like it otherwise. I haven't tried ziploks, but as long as you can get enough air out to keep smooth contact across the screen, they should work.
Offline Stymie
  • Unit(s): 898, 898
  • Software: Latest
  • Accessories: XM Weather, TM 360, AS GPS HS
« Reply #6 on: February 07, 2013, 02:53:52 PM »
I have a galaxy tab. will try it out this weekend. Thanks for the tip.
Offline Roddy
  • Scan,scan and rescan
« Reply #7 on: February 08, 2013, 10:28:35 PM »
I used a Zip-Loc Bag with a Acer 300 in it had heat build up problems. This was in South Carolina in april.
Roddy
« Last Edit: February 08, 2013, 10:30:02 PM by Roddy »
Scan,Scan and Rescan Roddy
  • Unit(s): 998c SI
  • Software: ??
« Reply #8 on: February 08, 2013, 11:09:30 PM »
I guess I should have mentioned this won't work on tablets with heat sinks/fans.  It does work on the galaxy as my brother and I used his for the navionics app on our last gulf trip....and it was hot as it gets outside.
Offline Stymie
  • Unit(s): 898, 898
  • Software: Latest
« Reply #9 on: February 12, 2013, 08:15:51 AM »
Worked well on my galaxy. Thanks again for the tip
Last post August 04, 2011, 04:51:20 PM
by terry0540
Last post May 26, 2012, 02:49:06 PM
Last post September 28, 2012, 10:14:45 PM
Last post October 16, 2013, 05:43:40 PM
by sstone2591
Last post January 10, 2015, 11:15:35 AM
by abraquelebout
Last post June 18, 2018, 10:01:57 PM
