Author Topic: Backup software for European (french) unit ?  (Read 17544 times)
Offline didier74
  • Unit(s): 1197 cx SI/1198 cx SI
  • Software: 6.310/6.490
  • Accessories: Ethernet switch
« on: January 31, 2013, 07:59:02 AM »
Hi,
Have just bought a 798 ci hd Si unit with software v6.250
It is a European unit ( am french )
I would like have a backup of this software on a SD card if one day have problem
Can i download it from the software download section ?
How choose the version for french unit ?
« Last Edit: January 31, 2013, 08:03:14 AM by didier74 »
Re: H
« Reply #1 on: January 31, 2013, 08:02:25 AM »
We dont have the French version on this forum.
Hopefully one of the guys near you can send you the needed software.
I am not sure what HB has but your might send them email and ask for en electronic copy.  Then you can store it on your computer put it on an sd if you need it....
« Last Edit: January 31, 2013, 08:04:23 AM by sonar2000 »
Offline didier74
Re: Backup software for European (french) unit ?
« Reply #2 on: January 31, 2013, 08:08:08 AM »
I ve registered my unit on Humminbird site
Do you think i could have this software from them ?
« Reply #3 on: January 31, 2013, 08:10:38 AM »
You should be able to download from the site based on your registration.. Make sure the code listed on the site is the same as what is in your unit.  HB generally only lists the most current code.
Hopefully they will be with yours..
Offline Rickard
« Reply #4 on: January 31, 2013, 08:24:31 AM »
I thought the same firmware version is used with domestic and international units. If the unit type is international it can be set up for a large number of languages, including french after upgrading.
Rickard
Offline didier74
« Reply #5 on: January 31, 2013, 08:29:23 AM »
I am not lucky... :'(
On Humminbird site i found the last v6.600
Offline didier74
« Reply #6 on: January 31, 2013, 08:33:17 AM »
My 798 ci Hd si must be a international unit no ?
First time i turned on , i had to choose language
Offline Rickard
« Reply #7 on: January 31, 2013, 09:21:12 AM »
Yes, it must an international model. The domestic model has no option for selection of language, according to the manual.
Rickard
« Reply #8 on: January 31, 2013, 12:00:16 PM »
There are some of the International model units that have a different software download file but I think that the 798cXi HD Si model you have uses the same software updates as the domestic 798ci HD Si units.
Offline navionic
« Reply #9 on: January 31, 2013, 03:20:23 PM »
Tell me what per units have different software, not to harm the device by downloading the firmware from this site?
Thanks.
Offline didier74
« Reply #10 on: January 31, 2013, 04:01:20 PM »
thanks Greg for your reply
going to call NAVICOM in france and see with them if i can download from their site the v6.250
i m very happy to meet you on this forum
you are great help for me
thanks one more time
Offline Rüdiger
« Reply #11 on: February 01, 2013, 04:39:26 AM »
Hi Didier
A lot of older versions of the firmware can be found here in the forum.
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=8
The language does not matter as long as it is the international version of the firmware.
mvh
Rüdiger
Finding is better than losing
Offline navionic
« Reply #12 on: February 01, 2013, 04:46:19 AM »
Hi Rüdiger
I agree with you.
But I would like to know what units are not suitable. My question has unfortunately remained unanswered.
Thanks.
Link to the old device. It probably about this item
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=23
« Last Edit: February 01, 2013, 04:50:17 AM by navionic »
Offline didier74
« Reply #13 on: February 01, 2013, 07:32:38 AM »
Thanks Rudiger and Navionic
I had found it
 but did not know if it was good for my international 798 cXi HD si unit
Now, i know i can download it
Offline navionic
« Reply #14 on: February 01, 2013, 07:37:39 AM »
I had found it
The battery must be properly charged
No action unit during reprogramming.
« Reply #15 on: February 01, 2013, 08:43:21 AM »
Hi Rüdiger
I agree with you.
But I would like to know what units are not suitable. My question has unfortunately remained unanswered.Link to the old device. It probably about this item
Excuse me for not replying sooner but I do have normal job duties that sometimes occupy my work time (I post on the boards when I have the time to do so – it is not a normal job duty) and I do have a life after work (I was teaching last night).
However, I do not track the software for the international units, so I couldn’t tell you which models have separate software.  Off the top of my head I can tell you that the Japanese version units have separate software but those are the only models that come to mind.
Offline navionic
« Reply #16 on: February 01, 2013, 08:51:10 AM »
Greg your help on the forum is invaluable. Albeit sometimes answer is rare, but it's fine that a representative of the manufacturer here. Another example your employee Deborah forgot about this forum. Although the service was not there on a rebound. Of course, Japanese and Asian units have their firmware.
« Reply #17 on: February 01, 2013, 09:23:57 AM »
Deborah is in the same boat I am (posts on boards when other duties are completed).  I know that she is pretty busy this time of the year.
Last post May 29, 2011, 02:03:27 PM
Last post July 07, 2013, 03:41:09 PM
by kerv
Last post October 26, 2013, 02:07:41 AM
by xSilmarilSx
Last post January 25, 2014, 04:54:42 AM
by Nitro78
Last post July 10, 2014, 11:48:42 AM
Last post January 23, 2015, 02:01:29 PM
Last post October 28, 2015, 09:43:13 PM
Last post September 27, 2020, 11:22:19 PM
