Author Topic: 798 ice fishing transducer rdcomendation  (Read 4401 times)
Offline D S
  • Software: 7.5
« on: January 22, 2013, 06:28:09 PM »
i have just purchased port bag(PTC-U) for my 798 .
now iam wondering what transducer is reccomended  for ice fishing?
I  now have a XTM 9 HDSI 180 T  ....will this work ok?
some suggest to get the xi 9200 ice ducer .......what would be the advantage?
will my SI transducer i already have not perform the functions i need??
thanks ds
stgr
Re: 798 ice fishing transducer rdcomendation
« Reply #1 on: January 23, 2013, 01:40:37 PM »
The HDSi transducer you have will work as an ice fishing transducer and will be able to show all of the sonar data that the XI-9-20 Ice Transducer will plus more.
When using the XI-9-20 you will either have to manually put the unit into the Normal operation mode each time you power it up to use it or you will need to go ahead and set the Demonstration menu to “Off”.  This is because the XI-9-20 does not have a temperature sensor so the unit may not recognize that you have a transducer connected.  The XI-9-20 is designed to be used for ice fishing and so comes with a float and can be held in place by the tether cable that comes out of the top of the transducer.
With the HDSi transducer connected the unit should start up in the Normal operation mode and start working just like it was on your boat.  You will have the same DualBeam 2D sonar you would have with the XI-9-20 transducer plus you will have the Si sonar as well (this could be helpful to locate fish and structure if you can get the transducer down below the ice).  The problem you may run into is that the HDSi transducer will need so sort of transducer holding rig to be used for ice fishing.
Last post May 28, 2009, 08:45:10 PM
Last post October 28, 2011, 10:40:38 AM
by raricker
Last post November 27, 2013, 12:56:29 AM
by rsb1
Last post December 11, 2013, 05:20:47 PM
by jepik
Last post February 01, 2014, 08:43:06 PM
Last post July 21, 2014, 01:19:03 AM
by Trav
Last post September 26, 2014, 10:49:44 AM
Last post November 21, 2014, 11:56:49 AM
by Rickard
