Author Topic: AS GR50 to Marine Radio NMEA  (Read 10415 times)
Offline Gene Ball
« on: January 06, 2013, 12:04:34 PM »
Tryin to make sure I got this right...
898 with the EXT GPS puck, tryin to connect a Standard Horizon Eclipse DSC + GX1150... GPS NMEA
The radio says,
Purple wire in +
Blue wire out +
Green wire  ground -
GR50 says,
GPS NMEA out Green wire
Control head NNMEA out White wire
Black ground -
So I'm thinking Purple & White, Blue & Green?
And of course, I think I got the grounds figured out ;)
TIA!
Gene
Offline Jim Jack
  • Unit(s): 998
Re: AS GR50 to Marine Radio NMEA
« Reply #1 on: January 07, 2013, 09:17:26 AM »
I currently have my 998 hooked to my GX1150 via (radio side - GR50 side) purple to white and green to black and it works fine (note NMEA out does not work in simulator mode). You have to have NMEA output turned on in HB to get position on radio. I'm thinking about changing to (radio side - GR50 side) purple to green, so that NMEA output does not need to be turned on.
HB Greg, do you know if using the GPS NMEA out works without turning NMEA output on?
Offline Gene Ball
« Reply #2 on: January 07, 2013, 09:37:49 PM »
Nice Jim, now I'm even more confused, but thats not hard to do  :P
Never owned a fish finder before..
Gene
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: January 08, 2013, 09:58:30 PM »
JimJack, yes, that green wire from the gps puck will work without NMEA output turned on. The white NMEA controlhead output is the same as the green output but with depth reading included and NMEA output has to be turned on.
GeneBall, Just checked the manual for that VHF radio. Page 17 has the wiring has:
WHITE - External Speaker (+)
SHIELD - External Speaker (–)
BLUE- NMEA Input (+)
GREEN - NMEA Common or Ground
PURPLE - NMEA Output (+)
..So you would need GPS output to VHF input.. .
So you would have to go VHF Blue wire to either GPS green or white wire(if white wire turn NMEA output on fish finder), and connect the VHF Green wire to GPS black wire.
If you needed to add additional devices that require a GPS,NMEA signal, you can use the VHF Purple wire (or the GPS green or white if the VHF is off)
« Last Edit: January 08, 2013, 10:08:21 PM by LocDown »
Last post May 10, 2010, 09:15:44 PM
by muskyhunter
Last post July 06, 2013, 12:41:00 PM
Last post June 29, 2014, 06:36:37 PM
by jjmoney
Last post July 09, 2014, 03:51:51 PM
by fishesman
Last post July 15, 2016, 02:14:47 PM
by pat.gearhart@icloud.com
Last post May 03, 2019, 01:00:49 AM
by DennyO
Last post May 29, 2020, 07:39:38 AM
by steelebob
Last post August 28, 2021, 07:38:11 AM
by 6speedy3
