Author Topic: H.B.Pc data to H.B. unit.  (Read 8667 times)
Offline Fay
  • Retirement is the best job I've ever had so far.
  • Unit(s): 798combo, TCR ID-1
  • Software: 7.12
« on: December 25, 2012, 06:22:57 PM »
When I make changes to waypoints in H.B. Pc. and copy changes back to chip, the changes do no
show on my unit.  What should I be doing to have waypoint changes transferred to unit?   ::)  Fay
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: H.B.Pc data to H.B. unit.
« Reply #1 on: December 25, 2012, 08:45:54 PM »
did you insert the card before or after you turned on the unit? it might not have loaded up.
Offline Fay
  • Software: 7.12
« Reply #2 on: December 25, 2012, 08:58:23 PM »
Unit was off and it is suppose to ask me if I want the changes but it never does.
Offline LocDown
    • Fishing Videos
« Reply #3 on: December 25, 2012, 08:59:24 PM »
try turning it on then inserting the card
Offline Fay
  • Software: 7.12
« Reply #4 on: December 25, 2012, 09:06:51 PM »
Damn LocDown, that did the trick.  I don't think I would have ever tried it that way.  thanks - ;) Fay
Offline LocDown
    • Fishing Videos
« Reply #5 on: December 25, 2012, 09:07:37 PM »
no problem.
Offline Fay
  • Software: 7.12
« Reply #6 on: December 26, 2012, 10:04:35 AM »
Does anyone know if this is the way it is suppose to work?  Insert card after powering up!  Fay
« Reply #7 on: December 26, 2012, 10:12:48 AM »
I don't know if this is the way it's supposed to work or not,
but this is how I update waypoints on my system.
One test is to turn off your unit and put in an updated waypoint SD card.
If they don't load in when you turn on your unit, then maybe
it's normal to put the SD card in while the unit is on.
Greg would know for sure.
Offline Jim Jack
  • Unit(s): 998
« Reply #8 on: December 26, 2012, 10:17:26 AM »
Yes, this is they way it is supposed to work. 2 or 3 updates ago HB changed the procedure from inserting chip then powering on to powering on then inserting the chip.
« Reply #9 on: December 26, 2012, 10:26:52 AM »
At the end of February of this year (2012), there was a change in software that made the units only attempt to load Nav Data if the memory card was installed after the unit was powered up.  This was in software version 6.180 (and all newer software versions):
“Disable Nav Data Auto Upload for SD Cards - Navagation Data stored on an SD card will no longer update automatically.  You will now be prompted as to whether you would like to update the Nav Data.”
This was a Customer requested feature change.
Last post December 04, 2012, 10:58:24 AM
by whosmatt
Last post April 04, 2013, 09:51:25 AM
by smaxwell
Last post May 05, 2013, 10:21:06 PM
by josmos23
Last post November 20, 2013, 05:27:51 AM
by lars
Last post February 26, 2014, 03:21:15 PM
Last post June 24, 2017, 12:53:18 PM
by 35wailin
