Author Topic: 1198c si combo bow mount  (Read 8631 times)
Offline basshole
  • Unit(s): 1198ci si combo
  • Software: ?
  • Accessories: ?
« on: December 18, 2012, 07:49:54 AM »
Is there another screen for bow mount or do I have to buy another 1198?
And is it possible to combine a smaller unit (600 series) with my 1198?
Offline wolfs4evr
Re: 1198c si combo bow mount
« Reply #1 on: December 18, 2012, 10:16:51 AM »
To get two you have to buy two, no remote screens available from HB.  IMO the best route is sticking to "same" units.  SI with a SI, DI with a DI, etc.  What I did.  898 on the console and a 798 on the bow.  Wish they were both 1198s but how it goes $$$ wise.  What is nice about going this route is if you connect them ethernet wise you can share the transducers.  So If I am on the bow I will change the consoles transducer in the ethernet settings to the bows transducer so I don't get any cross chatter between them for my daughter in the rear of the boat.  If we are out chasing Striper and trolling with the gas motor, etc I will change the bow to the consoles transducer on the transom.  That way I can set the front unit to whatever screen and use the consoles for other views.  I just have to look over the windshield for the bow units view.
Unless I am out of date on products there isn't a 500 or 600 unit with Ethernet.  What you have to look for if you want to be able to share waypoints, etc.  700HD units and up are all ethernet capable.
« Last Edit: December 18, 2012, 10:18:50 AM by wolfs4evr »
Offline basshole
  • Software: ?
  • Accessories: ?
« Reply #2 on: December 18, 2012, 10:55:15 AM »
That figures that they want to soak us for more$!
But thank you! you have been very helpful!
« Reply #3 on: December 19, 2012, 03:31:52 PM »
basshole,
You can connect an external monitor (screen) to your 1198c Si unit but Humminbird does not sell one.  This would be a dumb monitor in that it will only show what the original 1198c Si unit has on its screen.  Most that have done this have found that a marine type, sunlight viewable monitor is almost as much as a second unit.
Last post June 05, 2011, 12:58:14 PM
by edwardpic
Last post May 01, 2012, 04:38:28 PM
by Chet2142
Last post August 06, 2012, 03:42:11 PM
Last post January 10, 2013, 12:56:19 PM
by Zildjian
Last post April 07, 2013, 10:16:15 PM
by Scrutch
