Author Topic: 798si with standard Transducer TS 3 Switch and XTM 9 HDSI 180 Trolling Motor  (Read 9787 times)
Offline Gregpen
  • Unit(s): 798 ci hd si
Hi Guys,
So I've fitted a 798c SI to my console on a RAM mount and have used the standard SI transducer on the transom, I have added a TS 3 switch and a XTM 9 HDSI 180 T to the trolling motor. Do i need to change any thing in the Transducer Select Menu or is it simply switch through the TS3.
Cheers
Just use the TS3 switch Gregpen.  There is no menu selection in the 798c Si units for the HDSi transducer.  It uses the same “Compact SideScan” menu setting that the CSi transducer does.
Offline Gregpen
Thanks Greg for the response.
Last post June 05, 2009, 11:39:51 AM
Last post June 23, 2010, 09:17:15 PM
Last post July 05, 2010, 02:34:14 PM
by Wayne P.
Last post July 12, 2010, 07:23:12 PM
by Wayne P.
Last post January 02, 2012, 07:40:33 AM
by tommy29461
Last post May 19, 2011, 11:55:14 AM
by FuzzyGrub
Last post May 30, 2013, 05:14:51 PM
by RBrad
Last post May 12, 2018, 01:00:31 AM
by leeland
